Honda Injectors
Old Sep 21, 2007 | 05:31 PM
brett88's Avatar
Default Honda Injectors
I own a 1988 Honda Civic Wagon 2 wheel drive 5 door hatchback. I was told by my mechanic that I need the injectors to be replaced since there is a leak a outside one of the injectors. Its not a bad leak, but it keeps leaking. How long can I drive before I have to fix it. Problem is I am in between jobs and my honda is my only mode of transportation. My engine size is 1.5 liters if anyone wants to know
thanks
brett
Old Sep 21, 2007 | 06:12 PM
spastik's Avatar
Default Re: Honda Injectors (brett88)
the leak would either make you run lean (not good), or just dump your gas on the ground, which you would just be wasting your own money.. i would get it fixed as soon as you can to prevent any other damages in the future.
that is.. if your mechanic is telling you the truth about this
Old Sep 21, 2007 | 11:18 PM
Fuzzy Rhubarb's Avatar
So you got dpfi? If so, I'm pretty sure you have primary and secondary injectors. Both injectors can inject fuel to all cylinders. I could be wrong, though. You should really replace the injector. Here how from the magical service manual (I really suggest getting a copy!!)
For MPFI:
For DPFI:
Don't think the manual has one for DPFI. If I find it I'll post it. It shouldn't be too hard to replace though.
Modified by Fuzzy Rhubarb at 12:37 AM 9/22/2007
Old Sep 21, 2007 | 11:25 PM
STREETWERKZ's Avatar
a fuel leak not being a "bad" leak? are you smoking crack!? wait, please dont smoke crack next to your fuel leak.
fix it immediately. do not drive this car at all. engines get hot. fuel and an ignition source = FIRE!
Old Sep 21, 2007 | 11:27 PM
661rex89si's Avatar
Default Re: Honda Injectors (STREETWERKZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">a fuel leak not being a "bad" leak? are you smoking crack!? wait, please dont smoke crack next to your fuel leak.
fix it immediately. do not drive this car at all. engines get hot. fuel and an ignition source = FIRE! </TD></TR></TABLE>
you think they would know that lol. noobs really want to get flamed
Old Sep 21, 2007 | 11:39 PM
Default Re: Honda Injectors (661rex89si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 661rex89si &raquo;</TD></TR><TR><TD CLASS="quote">noobs really want to get flamed </TD></TR></TABLE>
Flamed two ways if he doesn't fix that leak...
Old Sep 21, 2007 | 11:45 PM
661rex89si's Avatar
Default Re: Honda Injectors (Fuzzy Rhubarb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fuzzy Rhubarb &raquo;</TD></TR><TR><TD CLASS="quote">
Flamed two ways if he doesn't fix that leak...</TD></TR></TABLE>
lol so true
Old Sep 22, 2007 | 05:41 AM
The_Undertaker's Avatar
75.168.105.221
any ef civic crx or ef b16 injectors will work they all are 240cc.
Old Sep 22, 2007 | 12:10 PM
143MYVTECEF's Avatar
Default Re: (1988hondacrxsiR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988hondacrxsiR1 &raquo;</TD></TR><TR><TD CLASS="quote">any ef civic crx or ef b16 injectors will work they all are 240cc.</TD></TR></TABLE>
Ah the last time i checked mpfi are not interchangable with dpfi. So just go to the local pick-a-part and snag both the primary and secondary injectors from the plentiful dpfi motors and there, for the price of admission you have two good injectors.
Old Sep 22, 2007 | 12:40 PM
thats it.....i vote ban!!!!!
Old Sep 22, 2007 | 01:27 PM
garageEF's Avatar
thats it.....i vote ban!!!!!</TD></TR></TABLE>
i second the motion
Old Sep 22, 2007 | 07:04 PM
~sp33~'s Avatar
EFB055
Default Re: (STREETWERKZ)
I voted this ages ago, you just jumped on my bandwagon.
Old Sep 22, 2007 | 07:19 PM
Default Re: (~sp33~)
that's a bandwagon i'd be glad to jump on.
BAN x1232043984723985632986345934659348563495765984365 !!!!!
Old Sep 22, 2007 | 08:21 PM
EF2_Sedan88's Avatar
a TRUE honda enthusiast
bb_one
Sep 11, 2006 08:51 PM
9SECQTR
Jul 3, 2004 08:31 PM
RABBIT9
Jun 24, 2004 08:12 PM
baonest
May 20, 2002 09:11 AM
