Painting side mouldings. Rubber prep??
Old Sep 21, 2007 | 04:44 PM
stealthmode62's Avatar
Default Painting side mouldings. Rubber prep??
92 civic hatch dx.
While looking to prep the side mouldings, I found these pieces to be like a hard rubber. I know some models come with painted ones, and I'm not sure if they're rubber or not. Basically, I have the hard rubber ones and I'm looking for tips on how to properly prep the mouldings for paint. The only thing I can come up with is epoxy primer?
Old Sep 21, 2007 | 08:04 PM
JDM_Acccord's Avatar
Default Re: Painting side mouldings. Rubber prep?? (stealthmode62)
bump.. i would like to know too.
Old Sep 23, 2007 | 07:04 PM
Default Re: Painting side mouldings. Rubber prep?? (JDM_Acccord)
No really, someone speak up.
Old Sep 30, 2007 | 09:51 AM
SOHC_me's Avatar
i recently painted some on an ek hatch. they had some deep scratches in them so i had to go all the way done to 120, but i finished sanding them down to 600. 400 would be alright though. just get out all the scratches.
Old Sep 30, 2007 | 04:47 PM
Default Re: Painting side mouldings. Rubber prep?? (SOHC_me)
I was looking more towards which primer(s) or additives to use to ensure the paint will hold on to the hard rubber surface.
Old Sep 30, 2007 | 08:50 PM
SOHC_me's Avatar
i used epoxy primer, only because i was spraying other parts at the same time though. regular primer will be fine though
Old Sep 30, 2007 | 09:53 PM
SneezinCD5's Avatar
Sand them with 400 and a grey scuff pad if needed, clean them with alcohol then spray adhesive promoter on them then you can prime/seal then paint them
Modified by SneezinCD5 at 11:04 PM 10/1/2007
kcatc
South
May 19, 2016 11:59 PM
suthernbred904
Paint and Body
48
Mar 27, 2009 09:25 AM
accomsrazor
Paint and Body
Jul 3, 2008 05:08 PM
djviet2000
Paint and Body
May 16, 2007 10:44 PM
1SlowSi
Mar 13, 2007 04:56 PM
