Trying to fine a new block
Old Sep 21, 2007 | 04:41 PM
freddysEF's Avatar
Default Trying to fine a new block
I have a 1990 civic hatch with a mini swap, D15 block with Z6 head. I was wondering if i can use a D16 block instead of my D15 or what are other blocks i can use for my car. Its still OBD0 but im planing on doing OBD1 soon.
Also for some reason when im standing still at traffic temp. gauge rises but the car is not over heating, then it goes away if i turn off the car or start to move does anyone know why is this????
Old Sep 21, 2007 | 04:46 PM
24TEN's Avatar
PHANTOM MENACE
Short answer-Yes, any SOHC D-Series block should work (1.5-1.6) basically anything from 88-00.
I don't know about you temp situation though. How far does it rise?
Old Sep 21, 2007 | 04:50 PM
Rexxer's Avatar
Default Re: (24TEN)
only block you cant use is the 1.5 hf block. and sounds like your radiator fan isnt working, and when you start going the fins on the radiator cool down a bit.
Old Sep 21, 2007 | 04:51 PM
freddysEF's Avatar
Default Re: (24TEN)
it goes just under the red line
Old Sep 21, 2007 | 04:53 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: (Rexxer)
Really? Is it the block itself that can't be used? Or the pistons...
For the temp thingy, my buddy had a similar problem. Said it went back to normal after he'd start to drive again. He said there was air in the lines. Try bleeding it and see if that resolves anything.
Old Sep 21, 2007 | 04:55 PM
Rexxer's Avatar
Default Re: (24TEN)
lol. ok just the pistons but sounds like hes just gunna grab another block and put head on not put one together =P
Old Sep 21, 2007 | 04:56 PM
freddysEF's Avatar
what would be the difference between the 1.5 and 1.6 other then the pistons and crank, ect
Old Sep 21, 2007 | 04:57 PM
24TEN's Avatar
PHANTOM MENACE
True
To be more specific then, be careful of the 8 valve motors which are D15B6 and D15B8. The first is from the 88-91 CRX HF model. The second is from the 92-95 Civic CX model (I have heard that after a certain year, the B8 blocks came with normal 16 valve pistons).
Aside from the crank and pistons, there will be rod size differences and also something you might overlook are the bearing/journal sizes.
Old Sep 21, 2007 | 04:58 PM
freddysEF's Avatar
im not just gonna put it one i want to build a block because im gonna build up my head over the winter so i want to do those two things over the winter
Old Sep 21, 2007 | 05:01 PM
Rexxer's Avatar
Default Re: (freddysEF)
for the most part their all the same..depending on the blocks internals. but the hf can only support 8 valves cause the pistons will hit the valves.
edit-- lol beat me to it.
Old Sep 21, 2007 | 05:06 PM
freddysEF's Avatar
well my head has 16 valves so i just need to fine a 1.6 that has 16 slats for the valves
Old Sep 21, 2007 | 05:11 PM
24TEN's Avatar
PHANTOM MENACE
All the 1.6 blocks are 16 valve so you should be good. If you can, locate a Z6 block so that you have a complete D16Z6 setup. Two other blocks you may want to consider are the A6 block (88-91 Civic/CRX Si/EX) and the JDM D15B VTEC block. I've read some arguements saying the A6 is the strongest internally due to different materials used and I've also heard arguements for the D15B VTEC having a specific rod/stroke ratio that is best but I couldn't personally verify either claim. Try searching it and see what you come up with.
Old Sep 21, 2007 | 05:15 PM
freddysEF's Avatar
Default Re: (24TEN)
thanks a lot all look into that
eg:R
Apr 19, 2014 08:56 AM
BIGef
Oct 17, 2012 07:25 PM
kaptr1d
Mar 15, 2004 04:51 PM
Nextelbuddy
Feb 10, 2004 09:23 AM
