Heater Core Question:
Old Sep 21, 2007 | 03:29 PM
sicky's Avatar
grammer nawzi
Default Heater Core Question:
Before you ask: EJ8 (97 ex coupe) with B16. Carry on.
Just put in a new battery and dropped a Phillips head screwdriver tip in my engine bay. While searching for that little bastard I noticed that there was a little bit of gunk (rust colored, tanish) and a tiny drop of green antifreeze on the top of the hose that goes from the motor to the heater core (the line that runs on the far left side of the motor, under the IM and into the firewall). Just wondering if that's a sign the core is going bad, or maybe the line needs to be tightened?
The car has never ran hot, nor really lost any coolant. Any advice/information would be awesome.
Old Sep 21, 2007 | 04:05 PM
pythoner's Avatar
you may just need to replace the hose...it could either amplify or solve your problem...most likely solve
Old Sep 21, 2007 | 04:06 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: Heater Core Question: (sicky)
did you pressure check your system.. to see if anything is leaking in that area?it sounds like maybe a hose or clamp..
dirtygerman
Apr 28, 2013 04:43 AM
MallyMall7
Mar 31, 2012 06:09 PM
sdinteg
Sep 17, 2007 06:31 AM
flip1199
Sep 3, 2004 05:22 PM
