Supension help!!!
Old Sep 21, 2007 | 03:18 PM
dan12288's Avatar
Default Supension help!!!
Hello every one,
Am plaining on putting 18x8 Enkei RP03 (sbc) rims on my car and want to lower my 2004 rsx type s , so that the wheels look better on the car. But i dont know anything about supension systems. from what i know ill only need lowering springs. but is that the only thing i will really need and whats the difference between coil overs and lowering springs? please help
thank you for looking!!
Old Sep 21, 2007 | 03:32 PM
NTCustoms's Avatar
a lowering spring is basically what it is, a spring. a coilover is a setup of a strut and a spring combo. Some coilovers such as the A-spec or Mugen SS are not adjustable, and offer a mild drop. others, such as BC N+ and Tein SS-P are adjustable, and offer a large parameter of height adjustment. FYI, running a lowering spring on stock struts will only decrease the life of the strut, and you may end up blowing them. Do it the safe way and get aftermarket struts such as Koni Yellows or Tokico Illuminas
Tyte-S's Avatar
Default Re: Supension help!!! (dan12288)
If you like to play with your ride height and your picky like me about how your car sits, then you will probably be more interested in coilovers, as most of them allow you to adjust the height to your liking. For springs,depending on how low you plan on going, you may want to look into a set of aftermarket struts. Leaving the stock ones on with the car lowered will wear them out faster. Also run a search on this topic for more info, cuz Lord knows its been covered a couple thousand times on H-T.
Old Sep 21, 2007 | 04:14 PM
dan12288's Avatar
Default Re: (NTCustoms)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NTCustoms &raquo;</TD></TR><TR><TD CLASS="quote">a lowering spring is basically what it is, a spring. a coilover is a setup of a strut and a spring combo. Some coilovers such as the A-spec or Mugen SS are not adjustable, and offer a mild drop. others, such as BC N+ and Tein SS-P are adjustable, and offer a large parameter of height adjustment. FYI, running a lowering spring on stock struts will only decrease the life of the strut, and you may end up blowing them. Do it the safe way and get aftermarket struts such as Koni Yellows or Tokico Illuminas</TD></TR></TABLE>
What if i just get the set of coilovers, do i have to still look at struts, or will the coilover do the job...?
Old Sep 21, 2007 | 04:19 PM
dan12288's Avatar
Default Re: (dan12288)
By the way coilovers are way more expensive than a set of springs..... unless some one knows were to find cheap prices on coilovers
Old Sep 21, 2007 | 08:51 PM
Grandhustleman86's Avatar
Ok your best bet for coil-over 'sleeves' are GroundControl....secondly yes you will need a new set of struts to pair up with those coil-over sleeves....running stock struts with either springs or especially coil-over sleeves your asking for trouble....look into Tokico Illumina's or Koni Yellow Adjustables....I have used both several of times and have never been let down....I teamed up the Koni's with Neuspeed Racing springs then installed a set of Progress Swaybars and got the 3 wheel motion going....but on a serious note run stick it out and get the struts man.
Modified by Grandhustleman86 at 8:14 PM 9/23/2007
Old Sep 22, 2007 | 10:42 PM
NTCustoms's Avatar
okay as i have said before, a coilover is the strut/spring combo. many companies already have these two paired together and refer to it as a coilover. so you do not need to look into struts. if you want lowering springs instead, you will need to look into aftermarket struts. Thirdly, there is something else you should know. Ground Controls, Skunk2 (before they came out with their newer edition)....these are not true coilovers. they are coilover SLEEVES, meaning they sit on top of the strut. where the lowering spring would normally sit, these replace. they offer the height adjustability of true coilovers but aren't as stiff and harsh. it all depends on what you want, a comfortable ride or something that'll really hold you while taking turns
Ej8.Pjay
Honda Civic (2006 - 2015)
Aug 23, 2013 05:10 AM
westminsterCA
Suspension & Brakes
Mar 19, 2007 11:54 AM
moores55
Jan 15, 2006 12:37 PM
SOUNDEFFECTS
Apr 18, 2003 03:41 PM
