vtec trouble
car = 88 crx
motor/tranny/ecu = 1990 b16a/y1/pr3
problem = vtec not engaging
ecu codes = none
bogs heavily @ 7000 rpm (major power loss)
direct me in the right direction?
ecu codes = none
maybe ur fuel pump its going bye bye
or maybe ur fuel press regulator its messing up and not giving u enough gas for that high rpm
time for new, cap, rotor and sparks and cables.....
vtec not engaging?? check all conectors on vtec solenoid and sensors....
vtec needs, oil press, temp, ,make sure they are all good....
reset ecu...etc
reset ecu...etc
have new cap, rotor, plugs, wires..
aem fuel regulator, i'm going to put the fuel pressure gauge on when i wake up, see what the pressure is at, (what should it be at? idle)
hmm, fuel pump has 240,000 kilometers on it.. maybe?
reset ecu = disconnect battery, start and let idle?
what if vtec solenoid isn't getting any power at 5200rpm? than what?
thanks!
thanks!
supergohan
12
Oct 7, 2013 05:43 AM
ensracer
Sep 15, 2005 10:15 PM
Se-rv-Tak
22
Apr 6, 2004 02:47 PM
