y8 with ls pistons???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pythoner »</TD></TR><TR><TD CLASS="quote">it won't work...wrong diameter piston</TD></TR></TABLE>
Not entirely correct ...
According to ::
https://honda-tech.com/zerothread?id=335078
.... obviously high compression and you 91 octane folks should consider a thicker head gasket. However, 12.5:1 can be driven daily on 92 octane. Since you have decided to open that sucker and upgrade the pistons you should also consider upgrading your rods. Whether you decide to shot-peen your stock rods or upgrade to some LS rods, it's up to you. The LS rods can fit a D series piston simple by removing a little material from the inside of the piston. When upgrading these, you should consider new OEM bearings and ARP rod bolts. Strength is always a comfort, right? The head is what traps all of the power in any engine. Be it naturally aspirated (N/A),......... "
<U>Posted by Spade; 2002; "Sohc it baby, cause its cheap!"</U>
Do your research
According to ::
Do your research
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">
According to ::
The LS rods can fit a D series piston simple by removing a little material from the inside of the piston. When upgrading these, you should consider new OEM bearings and ARP rod bolts. "
If you were to read instead of assume I was wrong (entirly possible
) you would realize that they were talking about LS <U>RODS</U> not <U>pistons</U> like metioned by the OP
the D series has a 75mm bore where as the LS has a 81mm bore...the numbers just don't add up
According to ::
) you would realize that they were talking about LS <U>RODS</U> not <U>pistons</U> like metioned by the OPthe D series has a 75mm bore where as the LS has a 81mm bore...the numbers just don't add up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pythoner »</TD></TR><TR><TD CLASS="quote">that would be a heck of a sleeve...none that are on the maket would work</TD></TR></TABLE>
It's been done...
http://www.d-series.org/forums...27924
But it's certainly NOT worth it...
It's been done...
yea its def. not worth it but i was looking towards the rods because they are stronger maybe can hold a couple extra lbs. of boost than the stock y8 rods
Modified by Midori Green at 7:22 PM 9/21/2007
VTgringo
Aug 1, 2003 10:04 PM
