Getting Bar'd.....I need help.....which throttle body?
I've got a jdm b16 that im getting bar'd. Smog is not a problem, only problem is I cant figure which throttle body I need. The motor is Obd1 and all the hoses need to match a del sol.
This is what I know. The charcoal canister and Evap are both supposed to run to the throttle body, via two nipples on top. I've been told the throttle body needs the Map and TPS located on throttle body, that it should be Obd1, and that its either B16 or LS.
The thing is, I have found an B16 tb with both sensors and no nipples, and an LS tb with one sensor and one nipple. Someone told me obd1 LS doesnt have both sensors.
So I need to know what throttle body do I need to Bar my Obd1 Jdm B16 in my crx
Thank you for your time
I just stood on top of a hill in a thunder storm and walked on the beach while watching the lightning
CRX MASE
Aug 2, 2005 02:01 AM
