Car at High at MPH on freeway! Q
oo yea it is more... so I need a new clutch basically? Anything to do with flywheel?
forgot to mention i got a stg 2 clutch and AcT light flywheel so yea.
well why would you built your top end and not get new valves? expecially with hc pistons.. are they domed hi comp? could be a reason. and if you can get up to 65 knowing you probably killed it cause you would be getting on the interstate.. you would know your clutch is slipping..
i mean i know i put a brand new clutch on my coupe and when i slam second it drags like it's fuckn gone already.. but it's a the fly wheel.. needs to be resurfaced.. but anyway let me know
what is domed hi comp?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm91CrxSi »</TD></TR><TR><TD CLASS="quote">are they domed hi comp? could be a reason. and if you can get up to 65 knowing you probably killed it cause you would be getting on the interstate.. you would know your clutch is slipping..
and I didnt understand the the last part of this...
u can also check ur clutch by being parked with the motor running and put the shifter in 5th gear and slowly let off the clutch. if it keeps running ur clutch is Shot- thats what i was told anyway
ill try your advices thx.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock99si »</TD></TR><TR><TD CLASS="quote">
or go about 30 and put it in 5th gear and gun it, if the rpms rise but the car doesnt move then its slipping.</TD></TR></TABLE>
I tried this today and it moved but the rpm dropped like crazy lol.. not enough power .. but rpm does not rise so.
FLCivic
15
May 31, 2004 09:22 AM
