BlueIntegraBoy [maplight question]
Old Sep 20, 2007 | 11:44 PM
Ex-Eg-Driver's Avatar
Default BlueIntegraBoy [maplight question]
Just got done with install...looks nice...ill try to show you pics tommorow in the day. When wiring up the white blue i pulled the neg. terminal. But when putting it back on...the light doesnt work!...also the dome light doesnt work nomore either...is it a fuse?
Old Sep 20, 2007 | 11:51 PM
BlueIntegraBoy's Avatar
Default Re: BlueIntegraBoy [maplight question] (JayKayNidas)
Maybe you popped a fuse. Check your interior light fuse.
Old Sep 20, 2007 | 11:53 PM
Hmm...so just replace right? would it keep popping? I would need to buy a 7.5v fuse? For interior light.
Old Sep 20, 2007 | 11:54 PM
Default Re: (JayKayNidas)
As long as the install went well, just replace the fuse. I mean, I can't see how it wouldn't work. You don't have any spare fuses on the side of the fusebox?
Old Sep 21, 2007 | 12:00 AM
I believe I do. Never touched down under there. Should be some. Does it have to be 7.5? and I dont see where it says interior light.
Old Sep 21, 2007 | 12:01 AM
I would go 10A max if you don't have 7.5A.
Old Sep 21, 2007 | 12:07 AM
THANKS!!!!
Old Sep 21, 2007 | 12:20 AM
hey man...they keep popping. Went through both spare fuses. Everytime I put them in.."pop"...what could be the problem?
Old Sep 21, 2007 | 12:30 AM
Did you connect the correct wire to the correct pillar wire? Are all the wires wrapped in electrical tape? All I can think of is the power wire is being grounded causing the fuse to pop.
Old Sep 21, 2007 | 12:33 AM
Okay. I will double check the wiring tommorow. Will post if I need help. Thanks though man.
jonobird
Jul 11, 2011 01:06 AM
Importn2oRacer
Oct 15, 2010 09:13 AM
hijayhawk
Jan 20, 2007 06:34 PM
SLOAZZ95
Oct 6, 2003 11:55 AM
