throwing codes. need help
Old Sep 20, 2007 | 07:11 PM
B16A JDM EG's Avatar
Default throwing codes. need help
hey im throwing code 15 - ignition out put signal and code 41 - oxygen sensor heater. my car seems to run fine but when i hit the gas and let off the throttle goes down to bout 400rpm and then goes back up to 900rpm. whats could be possible reasons for this? and wat can i do bout the codes?
Old Sep 21, 2007 | 03:51 AM
i have a jdm b16a sir II in a 95 coupe. if u all needed that information.
Old Sep 21, 2007 | 05:07 AM
crazyguy's Avatar
Default Re: (B16A JDM EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16A JDM EG &raquo;</TD></TR><TR><TD CLASS="quote">i have a jdm b16a sir II in a 95 coupe. if u all needed that information.</TD></TR></TABLE>
yeah i have the same engine too..just replace the o2 sensor.thats what happened to me before too and what kind of ecu are u running ?
Old Sep 21, 2007 | 05:12 PM
umm i believe last time i looked it was a p30
Old Sep 21, 2007 | 05:24 PM
n8dizzel's Avatar
you could also check IAC
Old Sep 22, 2007 | 08:13 PM
yeah i replaced it with another used one.
Boosted Chemist
12
Aug 1, 2004 08:14 AM
chris81
Feb 21, 2004 08:39 AM
The Punisher
Sep 1, 2001 03:11 PM
