need help on a four point harness
Old Sep 20, 2007 | 07:09 PM
billy_thekid's Avatar
Default need help on a four point harness
does anyone know the best way to install it in a crx?
i need hep
Old Sep 21, 2007 | 11:47 AM
GreenBean's Avatar
Default Re: need help on a four point harness (billy_thekid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by billy_thekid &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know the best way to install it in a crx?
i need hep </TD></TR></TABLE>
I think you can mount the lower harness ends to you factory seat belt locations...I have seen guys criss cross the shoulder harness into the rear cargo area...I think you are better off buying a cross car for the shoulder harnesses...Are you wanting to get rid of your factory belts?
Old Sep 21, 2007 | 11:54 AM
CRX Toad's Avatar
Not to rain on your parade but 4 point harness are worse than your stock 3 point belts in an accident. I you just must have 4 point setup to 5 point and you will thank yourself. Also get a harness bar, attaching to the floor creates downward compression when in an accident situation.
Old Sep 21, 2007 | 11:55 AM
89efDUSTY's Avatar
Default Re: need help on a four point harness (GreenBean)
You should definitely not be running a harness without a rollbar, you greatly increase your chance of injury/death without the rollbar. If your roll bar doesn't have a harness bar you can easily get one welded on. Then just mount the two lower points to the seat belt locations, and wrap the rear ones approximately 12 degrees above you IIRC. Sorry its been a while but please search and put safety before style. GL
Old Sep 21, 2007 | 11:56 AM
Trakhor's Avatar
Torque Junkie
Default Re: need help on a four point harness (CRX Toad)
I'm with Toad on this one....4 point is just asking for crushed ribs if you get in the "right" kind of accident. Crushed ribs lead to punctured lungs which leads to vomiting blood.....you get the picture?
Old Sep 23, 2007 | 11:29 AM
thanks or the help i wasnt going for looks i just needed a belt because i couldnt find a stock one. but luckily i found one so no foru point harness.
Mag00n
Aug 3, 2006 06:28 PM
VeilSide_Mas
41
Sep 5, 2005 08:57 PM
V8K1LLER
Feb 6, 2005 03:17 PM
tbcmorris
Mar 17, 2004 06:59 AM
camera obscura
14
Mar 26, 2003 06:41 AM
