why do my brake lights stay on?
Old Jun 17, 2002 | 05:10 PM
Agent Daimon's Avatar
Default why do my brake lights stay on?
it just started happening last weekend..the only way to turn it off is taking out the fuse.........helpplease!
Old Jun 17, 2002 | 05:48 PM
seekerONE's Avatar
Default Re: why do my brake lights stay on? (RIPDC2)
take a break everybody..i'll field this one
on the brake pedal bracket there is a switch(known as the brake light switch)
on the brake pedal arm there is usually a small round plastic piece the pops into a small hole(this is commonly known as the brake pedal stopper)
i suspect that you are missing the pedal stopper(common for these to break at this age)
goto honda, tell them you need pedal stopper...my guess is somewhere around $2-$3
Old Jun 17, 2002 | 06:22 PM
zcivic91's Avatar
Default Re: why do my brake lights stay on? (seekerONE)
if u get under the dash and look at the brake pedal ull see a round switch of sorts... now depress the pedal and ull see a lil button come out...well the lights will stay on if that button is partially out...so try pulling the pedal back toward the seat to push the button back in...if that makes the lights go out...then just glue a penny to that rubber thing where the button gets pushed in and its fixed!!
Old Jun 17, 2002 | 09:15 PM
EF_LSVtec's Avatar
Default Re: why do my brake lights stay on? (zcivic91)
Old Jun 17, 2002 | 11:25 PM
CimorelliCRX's Avatar
Default Re: why do my brake lights stay on? (EF_LSVtec)
You have brake fluid enough? That will cause it to come on, not enough brake fluid. Anyway good luck.
Old Jun 18, 2002 | 02:32 PM
Figure it out yet?
Old Jun 19, 2002 | 08:24 AM
hahahaha thats what i did thanks alot dude your smart
Old Jun 22, 2002 | 11:00 AM
kranked91dx's Avatar
Default Re: why do my brake lights stay on? (Lil Cs Zc)
I certainly aint smarter than anybody here, but Hey, lil cz, don't you think that the break switch is on the breack pedal???? if you don't know where the **** this one is situated, Maybe I'll take a guess and tell you to try the one between the clutch and the gas???' there is no other switch on the break pedal,
get some glue instead of tape, this will work better.
see ya
kranked
Old Jun 22, 2002 | 10:48 PM
jdblack1's Avatar
Default Re: why do my brake lights stay on? (kranked91dx)
How about just cracking the nuts loose and move the switch in a little
Old Jul 19, 2002 | 05:53 PM
yorace2win's Avatar
since were on this topic....my brake light on tha dash will not go out... ne help for that guys?
Old Jul 19, 2002 | 07:50 PM
T25_ZC's Avatar
Default Re: why do my brake lights stay on? (yorace2win)
let your e-brake down!!! lol, but really i'm not sure what could cause this!
Old Jul 19, 2002 | 08:39 PM
4g4me's Avatar
I think we may be discussing two different problems here. If the brake light on the dash is on, like earlier mentioned, put down the E brake, or check your brake fluid level. now if your Brake lights stay on when your foot is off the brake. you can glue pennies and all of that crazy ****, but if you want to do it right, adjust the damn switch. now if you notice this little plastic thing lying on your driver side floorboard, you will need to replace the stopper on the brake pedal and possibly adjust the switch too. Very easy, can be done in minutes. now if you can't reply to this post because you have a damn penny glued to your finger. Well, thats your problem.
chighizola9
Jul 20, 2013 01:46 PM
93grayeg
19
Sep 8, 2009 07:30 PM
ole' black crx
Lighting
Jul 3, 2008 06:04 PM
Sarkastik_one@hotmail.com
Sep 13, 2007 03:51 PM
88crxhfb16
11
Jul 28, 2005 08:07 PM
