jdm b16 problem wont idle
Old Sep 20, 2007 | 06:30 PM
bustah49's Avatar
Default jdm b16 problem wont idle
running a chipped p28. performance wise, awesome. it is loading up and smells like raw gas at idle. and it is also surging on idle. i tried another chipped ecu that my buddy had and it does the same thing. but its fine with a stock p28. and it is not throwing any codes with any of the ecus.i replaced(with known good parts) iacv,map sensor,plug(new),distributor, fuel pressure regulator,cleaned throttle body,adjusted the valves , . man this thing has me pulling my hair out. any help would be appreciative
i also am running one of those...straight through cheater catalytic convertors.
Old Sep 20, 2007 | 06:34 PM
crazyguy's Avatar
Default Re: jdm b16 problem wont idle (bustah49)
the straight through cat pipe should not cause the problem..have u checked the spark plugs firing order? all the ground wires are good ?i have a jdm b16 too running with a chipped p28 ecu..runs perfect and drives perfect..
Old Sep 20, 2007 | 06:35 PM
jdm91CrxSi's Avatar
yo plug up the new ecu.. disconnect your map sensor and see how it runs. IE- on the back of your mani. if it still fails to idle properly and there are no codes... idk what to tell you
bustah49's Avatar
Default Re: jdm b16 problem wont idle (crazyguy)
car screams when i drive it man. plugs are new and firing order is on.
Old Sep 20, 2007 | 06:36 PM
bustah49's Avatar
Default Re: jdm b16 problem wont idle (jdm91CrxSi)
Old Sep 20, 2007 | 06:37 PM
bustah49's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm91CrxSi &raquo;</TD></TR><TR><TD CLASS="quote">yo plug up the new ecu.. disconnect your map sensor and see how it runs. IE- on the back of your mani. if it still fails to idle properly and there are no codes... idk what to tell you</TD></TR></TABLE>]
tried that and the car shuts off. kills the motor
Old Sep 22, 2007 | 05:47 PM
bustah49's Avatar
please delete...car is fixxed.
Old Sep 22, 2007 | 05:52 PM
EJ1chevelle's Avatar
what was wrong with it man?
Old Sep 23, 2007 | 06:59 AM
bustah49's Avatar
Default Re: jdm b16 problem wont idle (93egB16A)
apparently it was the tps sensor. that was the only thing i did not replace on the whole motor. and it did not throw a code at all. si i figured i would try it. and it works.
schwing27
21
Mar 17, 2009 08:49 AM
mikeunreal2
31
Mar 12, 2006 10:28 PM
Passaudi1.8t
Feb 5, 2004 07:27 AM
Passaudi1.8t
Feb 4, 2004 11:13 AM
