need a little help hoisting the F..
Old Sep 20, 2007 | 05:45 PM
oem_certified_accord's Avatar
Default need a little help hoisting the F..
i need to know where to place the chain & hook so i can start working on it
Old Sep 20, 2007 | 05:59 PM
Default Re: need a little help hoisting the F.. (oem_certified_accord)
Old Sep 20, 2007 | 06:06 PM
GhostAccord's Avatar
There should be two lift brackets on the engine, the image blow shows then on the F22B2 engine. What is that and F22Ax?..no matter they should be the same. Lift from opposite corners of the head/block. Front right - rear left or rear right - front left.
If your recently purchased engine no longer has these lift brackets on it. Take them from your existing engine if possible. Or find a bolt or two that you can put through a link and into the block. AC Bracket bolts, motor mount bracket bolts...etc...etc
TravisCadello
72
Jun 4, 2009 08:53 AM
blackmfoggie
Aug 3, 2008 10:35 PM
Dec 1, 2007 06:54 PM
98civic94gsr
Dec 21, 2004 07:44 AM
2fknlo
Jul 14, 2004 10:05 PM
