89 si
ok i just got a 89 si crx and i need a engine wiring i was wondering if the wiring from a 90-91 would work and i have a 90-91 gauge cluster and i was wondering if the dash harness from a 90-91 would plug in to my 89 harness and work.
Modified by dkrex001 at 9:35 PM 9/20/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkrex001 »</TD></TR><TR><TD CLASS="quote">what will i have to do to get the dash harness to work</TD></TR></TABLE>
You will have to get a dash harness from an 89, the 90-91 is way different and will not plug in w/o extensive rewiring that is not even close to worth it. just get a 88-89 harness and plug it right in
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkrex001 »</TD></TR><TR><TD CLASS="quote">well i have a 90 cluster
can i repin the cluster plugs to make the 90 cluster work in a 89 crx si</TD></TR></TABLE>
Yes but you need the cluster hood from a 90-91 not to mention the hazard switch and dimmer switch, did I mention you will have to wire them up as well as figure out the difference between the 88-89 dimmer vs. the 90-91 dimmer, basically it takes a bit more than just repining your existing cluster plugs. I did mine this way, but it's alot of work and I only did it so I could run a 99-00 Si cluster in my 89.
edit: just looked at your myspace page....you HAVE an 89 Si cluster for sale??? why not just throw that in there???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecSyndrome »</TD></TR><TR><TD CLASS="quote">
edit: just looked at your myspace page....you HAVE an 89 Si cluster for sale??? why not just throw that in there???</TD></TR></TABLE>
that is not my cluster it is my friend myspace plus i have a 90 dash with every thing i just need to know how to wire up the plugs, dimmer and just help i like the 90-91 hood and i have all the parts
if any one has a complete 90-91 crx si harness front to back all
pm me
Modified by dkrex001 at 8:22 PM 9/26/2007
Modified by dkrex001 at 8:23 PM 9/26/2007
Modified by dkrex001 at 8:27 PM 9/26/2007
pm me
benn2k
12
Feb 19, 2011 03:10 PM
suspendedHatch
Apr 26, 2006 07:16 AM
RA122324
Jun 28, 2005 03:06 AM
