is the s2000 filter bigger than the regular civic filter?
Old Sep 20, 2007 | 04:30 PM
coot_er's Avatar
Default is the s2000 filter bigger than the regular civic filter?
i bought an S2000 filter for my first gen b16. i thought this filter was supposed to be smaller than the regular civic filter to increase oil pressure? anybody else use the s2000 filter on their b16?
Old Sep 20, 2007 | 04:49 PM
Jimweezy's Avatar
Default Re: is the s2000 filter bigger than the regular civic filter? (coot_er)
All honda filters are the same part number, except the s2k witch has a larger filter. I ran a s2000 filter on my 06 Si before it got stolen and it did quite well.
Old Sep 20, 2007 | 04:54 PM
SIred91's Avatar
Rainman
Every single filter for hondas is gonna be tiny except for Pilot, which you cant use...and the s2000 which you can use, but is a bigger filter.
Old Sep 20, 2007 | 04:55 PM
Jimweezy's Avatar
Default Re: is the s2000 filter bigger than the regular civic filter? (SIred91)
Damn i didnt kno the pilot had a larger filter?
Old Sep 20, 2007 | 05:07 PM
STREETWERKZ's Avatar
Default Re: is the s2000 filter bigger than the regular civic filter? (Jimweezy)
s2000 filter is larger and would decrease oil pressure. not something you want to use on a B series engine.
Old Sep 20, 2007 | 05:46 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: is the s2000 filter bigger than the regular civic filter? (STREETWERKZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">s2000 filter is larger and would decrease oil pressure. not something you want to use on a B series engine. </TD></TR></TABLE>
Old Sep 20, 2007 | 07:04 PM
coot_er's Avatar
Default Re: is the s2000 filter bigger than the regular civic filter? (***$nyper)
well ****, i thought it was supposed to increase pressure
Old May 24, 2008 | 02:16 PM
egab's Avatar
The Pilot uses the same size filter as all other Hondas part #15400-PLM-A02. The S2000 is the only exception part #15400-PCX-004.
Old May 24, 2008 | 03:28 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: is the s2000 filter bigger than the regular civic filter? (egab)
actually.. a little tidbit of Honda history, the oil filters that they USED to sell for the d and b-series were the same size as the s2000 filters.. For some reason, around 2002, they started making the stock oil filters for the d and b smaller. I still have an "old style" filter floating around my garage, and if i can find it, i will post pics.
I run the s2000 oil filter on my d16 and i have no issues with oil pressure.
Old May 28, 2008 | 04:46 PM
Patty's Avatar
Default Re: is the s2000 filter bigger than the regular civic filter? (sanimalp)
i thought S2000 filters raised the pressure too.
sorry.... threadjack.....will a hose clamp wrapped around the filter increase /stabilize the oil pressure?
xintegr
Aug 29, 2007 06:46 AM
rohec04
Aug 7, 2007 10:11 AM
iridebiketrials
34
Feb 19, 2004 07:03 PM
020
Jan 31, 2004 09:37 AM
