Can I use hydro b16 tranny parts in a ys1 gsr tranny?
Old Sep 20, 2007 | 03:53 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
Default Can I use hydro b16 tranny parts in a ys1 gsr tranny?
Old Sep 20, 2007 | 06:57 PM
Mista Bone's Avatar
D Tranny Guru
some.......what you wanna use?
Old Sep 20, 2007 | 10:55 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default Re: Can I use hydro b16 tranny parts in a ys1 gsr tranny? (full Circling)
yes. you can use every hydro b16 part and transfer it into your cable case.
Old Sep 20, 2007 | 11:25 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Can I use hydro b16 tranny parts in a ys1 gsr tranny? (not so civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by not so civic &raquo;</TD></TR><TR><TD CLASS="quote">yes. you can use every hydro b16 part and transfer it into your cable case.</TD></TR></TABLE>
thanks for your clueless input.
Explain the larger 3-4 GSR synchro.shift fork and how he's gonna make it work.
Old Sep 21, 2007 | 01:20 AM
i want to use this stuff in my ys1. will it work? http://www.hondamarketplace.co...33495
Old Sep 21, 2007 | 01:21 AM
also, what applications should i use for a quaife lsd? mfactory final drive? act clutch?
thanks in advance.
Old Oct 3, 2007 | 04:45 AM
randomae's Avatar
Default Re: (full Circling)
do you want people to do the research for you?
Old Oct 3, 2007 | 09:27 AM
WWDTrackRacer's Avatar
New User
Default Re: Can I use hydro b16 tranny parts in a ys1 gsr tranny? (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">
Bone, when I was looking @ PN's ... and I did not see a difference between 3-4 synchro for YS1 and the other b16 hydro trannies. The forks are different, but only because they went from rebuildable multi-peice to welded 1-peice.
Are the S80 (GSR) 3-4 forks different? I never researched this...
Modified by WWDTrackRacer at 12:53 PM 10/3/2007
Old Oct 3, 2007 | 09:41 AM
Default Re: Can I use hydro b16 tranny parts in a ys1 gsr tranny? (WWDTrackRacer)
more "clueless input"...the s80 3/4 fork is no different then a hydro b16 3/4 fork.
Old Oct 5, 2007 | 04:11 AM
beef-cake's Avatar
so what is stronger, rebuildable or solid one piece forks?
axionm1k
Apr 14, 2008 03:36 PM
mistajdm
Nov 3, 2007 10:45 AM
tana
Mar 16, 2006 11:18 PM
trooper0641
Dec 11, 2003 03:10 PM
