rear disk brake conversion help
hey guys just looking for some help just got the rear disk brake setup off a 94 integra ls im putting it on my 00 ek hatch just wondering if you guys could show me the light on how to make this conversion a successful one thx
Basically unbolt and bolt on the new assembly. Very straightfoward.
Remove the console above the ebrake and unhook #5 and #8 from #3. Remove #13 (2) from the chassis to release the ebrake cables.
Do the following to both sides: Undo the soft brake line from the hard line. Unbolt #17 from the chassis, #20 (2) from the chassis, #19 from the LCA, #18 from the trailing arm assembly.
o wow thank i think that will help alot. but is this right? seeing that i got this setup off of a 3 dr hatch ls instead of the sedan then the cables should just line up perfect right?
ok now i also got the master cylinder and hub assemble will i need that also in this conversion seeing how the ls had abs and of the course the ek doesnt but im only switching the rear not the front?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Cables should work. I put 3 dr Integra cables on my 92 hatch. If they are too short, 99-00 Civic Si cables will definitely work.</TD></TR></TABLE>
i used DB8 cables on my ej8 and it worked fine.
mynameizstitch
10
Dec 13, 2009 03:06 PM
stickyfingers
Jun 30, 2005 09:22 PM
Del_Sol_s
Feb 3, 2005 01:30 PM
