1990-1993 Accord ECUs
Old Sep 20, 2007 | 02:50 PM
Oregonized's Avatar
Default 1990-1993 Accord ECUs
Are they all compatible? Can I take an ECU from a 1992 EX and plug it right into a 1990 LX?
Old Sep 20, 2007 | 03:07 PM
awdgsx96's Avatar
Default Re: 1990-1993 Accord ECUs (Oregonized)
Was there a vtec engine in the 4th gens?
If there was, you shouldn't put a vtec ecu on a non-vtec engine. You'll throw a CEL right off the bat, and I think a/f and timing plots would be off
Old Sep 20, 2007 | 05:03 PM
GhostAccord's Avatar
Default Re: 1990-1993 Accord ECUs (awdgsx96)
Yes you can, All the P0A Accord ECU's from 1990-95 F22Ax engines are interchangeable. To be safe make sure you match the ECU with your type of transmission Auto/Manual. The only exception would be the 94-95 EX. It is an F22B1 VTEC P0A ECU so it will throw a CEL if used with an F22Ax Accord.
Old Sep 21, 2007 | 01:43 PM
awdgsx96's Avatar
Default Re: 1990-1993 Accord ECUs (GhostAccord)
I thought they stopped the F22Ax in 93 or 94. My 95 is the B2
Old Sep 27, 2017 | 04:06 PM
Arkansas_Coils's Avatar
Adding onto this,
I have a 1992 Accord ex coupe manual. I'm trying to figure out what other ecu's are compatible with it as to save money.
loudlownslow
May 8, 2011 02:36 AM
bdmlilburn
Apr 8, 2011 12:34 PM
sixfourkiller
May 7, 2009 03:28 PM
T9U4ReBgO
Feb 28, 2008 11:42 AM
