Best motor to get 300hp with itb???
Old Sep 20, 2007 | 02:15 PM
Dr. Phil's Avatar
Default Best motor to get 300hp with itb???
I've been doing some research alittle, but I would like to come here and aske what you guys think. I want to get 300hp all motor with itbs. I would like to know what motor should I go with, or mix and matches like putting a different head on a different block. I don't need long answers. Just enough to do more research with your answer. Thanks
Old Sep 20, 2007 | 02:20 PM
cartune network's Avatar
Default Re: Best motor to get 300hp with itb??? (Dr. Phil)
do u plan on driving on the street and running it on pump gas?
u could either do a seriously built h22
or u could do a built k24/k20
but i dont think either of those will run on pump gas to well.
Old Sep 20, 2007 | 02:27 PM
Combustion Contraption's Avatar
EASY 300 hp.
Old Sep 20, 2007 | 02:29 PM
DARKB20's Avatar
if you have the money a built k24/k20
Old Sep 20, 2007 | 03:16 PM
kpowerdhatch's Avatar
yea you're looking at big big money to make 300 whp all motor. you're best bet is k24/k20.
go on k20a.org and start doing some research, you'll see its quite a task. 250-270whp is a little more realistic.
Old Sep 20, 2007 | 03:21 PM
98vtec's Avatar
moderator emeritus
https://honda-tech.com/zerothread?id=1339161
https://honda-tech.com/zerothread/1608375
https://honda-tech.com/zerothread/1547533
https://honda-tech.com/zerothread/2068126
https://honda-tech.com/zerothread/1810996
talk to some of the big guys here and open your wallet to them, i hope its deep. Your talking about a completely custom engine.
Old Sep 20, 2007 | 05:52 PM
Top Ramen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr. Phil &raquo;</TD></TR><TR><TD CLASS="quote">I want to get 300hp all motor with itbs. </TD></TR></TABLE>
You're not providing much info here - chassis? budget? use?
So........hell, go with a C32. ITBs, a good header and a decent tune will put you over 300 hp without touching the long block.
With no info at all, I'm tempted to suggest a SBC.
Old Sep 20, 2007 | 09:23 PM
SoCal EJ1's Avatar
Endyn's got a B series that makes over 300 on 91 octane. Probably cost you $15000+ to replicate it though.
Old Sep 21, 2007 | 05:57 AM
b19coupe's Avatar
Default Re: (SoCal EJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCal EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">Endyn's got a B series that makes over 300 on 91 octane. </TD></TR></TABLE>
Dubious.
K24 punched to a 2.6L will get you to 300 quicker than most Honda engine options, all motor.
Old Sep 21, 2007 | 07:25 AM
VtecKiDD's Avatar
Default Re: (b19coupe)
Turbo GSR
EASY 300hp, but not ITBs
seriously though, a 300whp NA engine is $20,000 if its a B series an not much cheaper if its a K series
thats just the MOTOR, not factoring in trannys, mounts, clutch, tuning, engine management, etc
Old Sep 21, 2007 | 07:36 AM
Dr. Phil's Avatar
I have 94 accord ex coupe 5 speed
Old Sep 21, 2007 | 07:38 AM
VtecKiDD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr. Phil &raquo;</TD></TR><TR><TD CLASS="quote">I have 94 accord ex coupe 5 speed</TD></TR></TABLE>
then it will cost $30,000
if your serious, you need a built H22, one that will NOT run on pump gas an will never see the street
be more realistic man, 200-220whp with an H22 is a good start. Do an H22 swap an take BABY steps.
if you really want 300whp then your only option is Turbo if you want to keep the cost under $5000
Old Sep 21, 2007 | 10:55 AM
Lscivic1999's Avatar
Default Re: Best motor to get 300hp with itb??? (VtecKiDD)
Searching before posting is the key..
Old Sep 21, 2007 | 01:32 PM
advangs's Avatar
What about a built h22 (pp head,cams, etc)with bc stroker? what should that be worth? think he could get pretty damn close..?
eagleclawracing
Feb 13, 2010 05:10 AM
Tornadom
12
Jan 2, 2006 06:25 PM
ALLMOTORD16Z6
Aug 4, 2005 01:25 AM
jaydmcrx
Jan 17, 2004 01:32 PM
boosted_dc2
Oct 13, 2003 08:34 AM
