New motor mount quesiton
I pretty much need new motor mounts for my car...Looking as hasport but i have heard that they cause the car to vibrate a lot....are there any less stiff mounts out there that provide more support than OEM? I have already put in the ES motor mount inserts and the vibration wasnt bad with them so if i could duplicate that i would be happy. thanks for the help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16b-EJ8 »</TD></TR><TR><TD CLASS="quote">I pretty much need new motor mounts for my car...Looking as hasport but i have heard that they cause the car to vibrate a lot....are there any less stiff mounts out there that provide more support than OEM? I have already put in the ES motor mount inserts and the vibration wasnt bad with them so if i could duplicate that i would be happy. thanks for the help</TD></TR></TABLE>
if that is the case then stick with thees inserts, other than that, oem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
if that is the case then stick with thees inserts, other than that, oem.</TD></TR></TABLE>
Gotcha...only thing i do not like about the inserts is that they squeak really annoying.
Gotcha...only thing i do not like about the inserts is that they squeak really annoying.</TD></TR></TABLE>
try using es lube. they sell them at autozone. it'll prevent the mount fomr squeeking.
try using es lube. they sell them at autozone. it'll prevent the mount fomr squeeking.</TD></TR></TABLE>
Cool thanks
Cool thanks
mugen or spoon bushings are stiffer than oem but not as stiff as hasports. plus you retain the lower torque mounts with them. they're pretty pricey though.
civicsi18
Oct 27, 2008 12:05 PM
meagainsttheworld
Jul 26, 2008 10:26 AM
