GSR runs poorly...NO power
Old Sep 20, 2007 | 02:01 PM
peter17212's Avatar
Default GSR runs poorly...NO power
I just got a 2000 GSR and the guy said it was driving fine but couple days ago it started driving like crap. It has power in the Higher cams but in the lower it barly has any. i knowdest that the car smokes a bit so i think it burns some oil. also i knowdest that the car was driven on advanced timing so i adjusted and it was better but still drives like ****. it almost feels like its not getting enough fuel. Please help
Old Sep 20, 2007 | 02:07 PM
Azn Kenny's Avatar
Clogged fuel filter?
Old Sep 20, 2007 | 02:10 PM
peter17212's Avatar
Default Re: (Azn Kenny)
but wouldnt it feel the same in the highers cams when the fuel filter is cloged
Old Sep 20, 2007 | 05:47 PM
95 integra's Avatar
Default Re: GSR runs like ****...NO power (peter17212)
Sounds like something is messed up with your MAP or TPS. Check engine light?
Old Sep 20, 2007 | 05:50 PM
peter17212's Avatar
Default Re: GSR runs like ****...NO power (95 integra)
The engine light is on... how would i know if it s map or TPS
Old Sep 20, 2007 | 05:51 PM
IntegrasAreBest's Avatar
i knowdest?
Old Sep 20, 2007 | 06:05 PM
95 integra's Avatar
I'd suggest working on that check engine light. There is a how-to in the FAQ topic at the top of the forums.
Old Sep 20, 2007 | 06:11 PM
g2daturbo's Avatar
what yr gsr either flash codes or use a scan tool and fix the check engine,.more than likely that be solve ur problem
Old Sep 20, 2007 | 06:14 PM
myfirstdc2's Avatar
Default Re: GSR runs like ****...NO power (g2daturbo)
are u kididng me? it clearly says "2000 gsr" anyway pull the codes and see what they are. then u can diagnostic the problem from there. kinda shooting blanks without full details of information of problem/problems
Modified by myfirstdc2 at 5:48 AM 9/21/2007
Modified by myfirstdc2 at 5:49 AM 9/21/2007
Old Sep 20, 2007 | 06:18 PM
peter17212's Avatar
Its a 2000 GSR...
Old Sep 20, 2007 | 06:58 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: (IntegrasAreBest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegrasAreBest &raquo;</TD></TR><TR><TD CLASS="quote">i knowdest?</TD></TR></TABLE>
"noticed"
OP: dude ...the check engine light is on. Maybe you should check the engine. lol that light doesn't come on for the hell of it. Get the codes read. Autozone will do it for free. Once that is done, call a honda dealer and ask them to tell you what the code means. Your problem could be a possible 50 million billion things. The code pulling will narrow it down greatly.
jdmwojo
May 3, 2011 09:57 AM
legends
Jun 8, 2006 08:36 PM
neona
Oct 2, 2003 06:11 PM
TruePlayaz114
Nov 20, 2002 09:21 AM
