GSR SWAP (ACTING SLUGGISH)
Old Sep 20, 2007 | 01:49 PM
AccordOn18z's Avatar
Default GSR SWAP (ACTING SLUGGISH)
Seems like in 1st gear or 2nd it is baffled like and then it kicks out of it and runs smooth...like its puttering...im thinking injectors but anyone else have a idea?
Old Sep 20, 2007 | 01:53 PM
jdm24seven's Avatar
Default Re: GSR SWAP (AccordOn18z)
Old Sep 20, 2007 | 01:54 PM
Default Re: GSR SWAP (Amir909)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Amir909 &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
whats that suppose to mean i dont speak thumbainian
Old Sep 20, 2007 | 02:05 PM
Azn Kenny's Avatar
Clogged fuel filter maybe?
Old Sep 20, 2007 | 02:08 PM
Default Re: (Azn Kenny)
im gonna replace that also....looks like its been a while since it was done...im gonna get valves adjusted also.
Old Sep 20, 2007 | 02:14 PM
SkankyEJ7's Avatar
Default Re: (AccordOn18z)
things i would check
vss ( it can cause some weird ****)
o2? (my car was really sluggish when mine went out)
my injectors went out, it just idled terrible and would break up in the higher rpms like over 5.
igntion? could be anything in the dizzy
Old Sep 20, 2007 | 02:17 PM
Default Re: (SkankyEJ7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkankyEJ7 &raquo;</TD></TR><TR><TD CLASS="quote">things i would check
igntion? could be anything in the dizzy</TD></TR></TABLE>
thats what its doing would it cause very small amout of smoke?
Modified by AccordOn18z at 11:42 PM 9/20/2007
Old Sep 20, 2007 | 03:09 PM
anyone else
Old Sep 20, 2007 | 07:07 PM
sh0rd87's Avatar
my h22a is doing the same thing. bogs out in lower rpm's and has no power? someone told me it was the ecu but i got a new one and still didnt fix it. if you figure it out pm me if i figure mine out ill pm you
Old Sep 20, 2007 | 07:34 PM
b18cDelSlo's Avatar
Default Re: GSR SWAP (sh0rd87)
90% sure it's the distrubitor. seen 3 hondas do this. it was the case everytime. something to check.
Old Sep 21, 2007 | 02:40 PM
Default Re: GSR SWAP (b18cDelSlo)
well me and mikey (boostedcivicsir) took my p28 out and used his Hondata P28 (i think) in it and it was doing the same thing. Vtec is crossiong over and the setting were all changed on the VAFC. I put on a purge valve also today to get rid of some of the smell. The bogging is caused by running on 3 cyls. Im going to do Dist cap. rotor plugs and wires tomarrow and ill let you know from there...if worse comes to worse ill get a new dizzy and a p30
EL MIGGZ
Jan 21, 2008 07:41 PM
lilo_goki
Mar 8, 2007 07:27 AM
iHOPEyouCHOKE
May 24, 2006 02:11 PM
EJ8 GSR-T
May 14, 2006 12:53 PM
BLK99VTECR
Oct 17, 2004 06:26 PM
