Exhaust Leak?
Old Sep 20, 2007 | 11:19 AM
CRX MASE's Avatar
Default Exhaust Leak?
I have an exhaust leak were the exhaust manifold meets the cat. I thought it was the donut gasket, so i replaced it, and i still have the leak. I jacked up the car and let my buddy rev the engine and i see that the exhaust manifold is pulling away from the cat causing the leak. So is it possible the flex springs are wore out?
Old Sep 20, 2007 | 11:23 AM
EL Vap133's Avatar
Default Re: Exhaust Leak? (CRX MASE)
Do you have a cat? If so, is your cat clogged? Are the bolts loose? I can't see how those springs can be loose, have you tried compressing them together and see how tough they are?
Old Sep 20, 2007 | 11:24 AM
The_Undertaker's Avatar
75.168.105.221
Make sure exhaust manifold is torque down to spec. Make sure cat flange bolt are torqued. And make sure the gasket from exhaust manifold to downpipe is torqued down. If this is not the solution check for cracks in the exhaust pipes.
Old Sep 20, 2007 | 11:28 AM
CRX MASE's Avatar
Default Re: (1988hondacrxsiR1)
I dont believe the cat is clogged, it looks brand new. The only thing i can think is the springs arent as strong as they use to be, causing the manifold to pull away from the cat.
Old Sep 20, 2007 | 11:30 AM
75.168.105.221
So replace the old springs. And invest in some quality springs for proper maintainence. Good Luck.
Old Sep 20, 2007 | 11:34 AM
EL Vap133's Avatar
Default Re: (CRX MASE)
Go to the junkyard and get some springs and see if that resolves it.
Old Sep 20, 2007 | 11:42 AM
CRX MASE's Avatar
Default Re: (EL Vap133)
I guess thats what im gonna do. Hopefully that will fix the problem.
Old Sep 20, 2007 | 11:44 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX MASE &raquo;</TD></TR><TR><TD CLASS="quote">I guess thats what im gonna do. Hopefully that will fix the problem.</TD></TR></TABLE>
Try and get some from an EG, they're a little longer and easier to work with. At least in my experience.
redm3turbo
Jun 4, 2011 04:33 PM
thunderlips
Jan 9, 2009 01:39 PM
YoungKadafi
Oct 26, 2006 04:03 PM
vtecpoweredsol
May 14, 2005 10:06 AM
-[95cxhatch]-
Nov 6, 2003 05:47 AM
