iac voltage
Old Sep 20, 2007 | 10:35 AM
v8 integra's Avatar
Default iac voltage
ok so i tested the iac voltage on my car and i get a 12. somthing on 1 wire and the other wire i get 0...on my integra wich works perfectly fine both wires for the iac plug have power..any suggestions on what i should do?it all of a sudden just went bad?? i really need help cuz the engine idle is horrible..
i have a jdm p30 obd1 ecu with a obd2 harness,,,,
thanks h-t!
Old Sep 20, 2007 | 02:21 PM
v8 integra's Avatar
bump
Old Sep 20, 2007 | 02:50 PM
Relic1's Avatar
one line should be 12V (ignition power)
the other should be tied to an ECU pin that PWM's the output to move the plunger in and out.
with everything hooked up and the car not running you should have 12V on both wires. it should be less than 12V on the ECU's control wire with the car idling.
RACEPAK
Engine Management and Tuning
Jul 25, 2010 11:28 AM
jackiewogn518
Feb 27, 2010 10:54 PM
97hatchb16
Sep 4, 2006 08:42 PM
u2civic1
Aug 1, 2003 01:11 PM
