rear disc brake conver.
i got a 94eg cx and i got rear si disc brake conver. i was wondering if i needed the prop valve and what ebrake cables i use.
thanks in advance
thanks in advance
i don't know about the prop valve i think your stock one will work but if the si one is more powerful it will help your stoping power more
as for the ebrake cables you need the ones that come off the si (the ones with the rear disk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mckrank313 »</TD></TR><TR><TD CLASS="quote">i don't know about the prop valve i think your stock one will work but if the si one is more powerful it will help your stoping power more
as for the ebrake cables you need the ones that come off the si (the ones with the rear disk)</TD></TR></TABLE>
Prop valve has nothing to do with making your brakes more powerful. It changes the bias between the front and rear brakes. Ebrake cables for the 92-95 civic si will work or ones for the 94+ integra they use the same part #
*Boostwerks*
Apr 26, 2007 10:25 AM
