RPM gauge not working
I recently bought a 2001 4 door Civic EX. The RPM gauge has been acting up lately. Normally the car idles at about 600 RPMs. Now the car is idling at 3000 RPMs. Also when I turn the car off the RPMs don't drop they stay at about 2000. It appears the gauge is either stuck or completely broken. Is this gauge controlled by a fuse? How easy it to replace the gauge? What can I do to diagnose the problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 »</TD></TR><TR><TD CLASS="quote">The gauge is not controlled by a fuse. You would need to pull the cluster out, and re-seat the needle.</TD></TR></TABLE>
Troof... But I find it kind of odd that it just slipped on it's own... might want to check for wear when you readjust it, it may just happen again.
Needs to be About 20% Cooler
u could allways try to sweep the needles see if that buys anything b4 u tear the cover off (and if your me split in half and in your fit of rage spill your beer on your seat staining it
hold trip button down.
turn on headlights
turn on ignition
turn headlights off-on-off
release trip button and quickly press 4 times.
)hold trip button down.
turn on headlights
turn on ignition
aznnikeballer887
May 5, 2008 11:08 PM
