Blox springs and Valves
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988hondacrxsiR1 »</TD></TR><TR><TD CLASS="quote">BLOX parts are the same as skunk2 parts same agressive parts for added horsepower. Make sure to increase cams too.</TD></TR></TABLE>
Not all there parts are the same. What is, "increase cams too"?
So you are using the blox springs and valve then or u just fan of blox?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad »</TD></TR><TR><TD CLASS="quote">
Not all there parts are the same. What is, "increase cams too"? </TD></TR></TABLE>
I think he means get a more aggressive cam. That would be too easy though, wouldn't it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1FSTNDN »</TD></TR><TR><TD CLASS="quote">
So you are using the blox springs and valve then or u just fan of blox? </TD></TR></TABLE>
He just likes hearing himself talk. Wait until somebody else with some experiences with BLOX can chime in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988hondacrxsiR1 »</TD></TR><TR><TD CLASS="quote">To increase means to upgrade and mostly all Blox parts are the same to skunk2 parts. They have the same goal to achieve power than OEM.</TD></TR></TABLE>
So does that mean it is the same as Mugen, Toda, Spoon, Buddy Club, etc cause they all increase power over stock parts?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988hondacrxsiR1 »</TD></TR><TR><TD CLASS="quote">Yes that is why they have different stages to achieve your power gain. Either to modify overstock or to have a weird idle stage at toda killa cams.</TD></TR></TABLE>
wow.... wow
wow.... wow
Check this link out http://www.bloxracing.com/ and this skunk2 link http://skunk2.com/index.php They both achieve in powerband increase. Either company will statsfied your needs.
I used blox cams with the required upgrade but moved on with skunk2 cams and their requirement not a difference in lift and duration time. Feels the same from both company. My powerband goal was 230hp All motor now.
thanx for your guys input. I just called my friend Mr. Shagday at skunk just order all of the D16Z head stuff like cam, cam gear, valve,spring and ret.... Reason i was asking someone was selling cheap because he sold the car and didn't needed anymore. thanx again.
