Oil Filter
Old Jun 17, 2002 | 02:42 PM
Jaminak's Avatar
Default Oil Filter
I just got a 98 CR-V for my wife. I can't get the oil filter off though. It is a filter. I tried to muscle it off. That didn't work. I got one of those 'six in one' wrenches and it didn't fit on the larger side because of the engine mount. I've tried the various sizes of normal loop-type filter wrenches. None of those work. I was going to try and hammer a screw driver through it, but the only leverage I have to do this is from undernieth, right where my head would be. I've never done that before either. Any suggestions?
-Jamin
Old Jun 17, 2002 | 02:57 PM
Spade's Avatar
Default Re: Oil Filter (Jaminak)
Just get some pliers and grab the side of the filter.......i.e. dent the hell out of it. and use the newly made flat part as the thing to grab to rotate the filter.
Old Jun 17, 2002 | 03:55 PM
Chiovnidca's Avatar
I use a socket on them.
[Modified by Chiovnidca, 7:56 PM 6/17/2002]
Old Jun 17, 2002 | 04:40 PM
Tweakmeister's Avatar
Default Re: Oil Filter (Chiovnidca)
I had this with my integra....
Two options...
Vise-grip ("the bitch" as one of my SAE friends tore the thing off)
or
Drive a flat head through it (I've personally done this one) and let hot oil come out all over you...then after you run out of room you have to hit another hole into the filter again (did this about 5 times). Ruined a shirt, but got the oil filter off.
Old Jun 18, 2002 | 07:11 AM
Jaminak's Avatar
Default Re: Oil Filter (Tweakmeister)
Thanks for the ideas. At least it's a CR-V and there is lots of room under there
Old Jun 18, 2002 | 07:42 AM
BROOD's Avatar
I always use those oil filter sockets that fit tightly over the end of the filter and allow the use of a ratchet to break the filter loose. Always works like a charm.
There are a few different sizes so you usually have to try a few to find one that fits.
Strap wrenches suck
Screwdriver method - works,but messy as hell
[Modified by SLPR, 8:44 AM 6/18/2002]
Old Jun 18, 2002 | 07:53 AM
YeuEmMaiMai's Avatar
take a screw driver and punch it though the filter and twist it off
Old Jun 18, 2002 | 09:21 AM
slooowDX's Avatar
Default Re: Oil Filter (YeuEmMaiMai)
get oil filter pliers from you're local auto parts store, i find those to work the best
Old Jun 18, 2002 | 12:50 PM
Chiovnidca's Avatar
Default Re: Oil Filter (SLPR)
If it's a Honda filter on your CRV, the socket size is 80/15.
Old Jun 18, 2002 | 02:14 PM
Halo's Avatar
oil filter socket hands down the best and I bought from Pep Boys for $1.99 works like a charm
Old Jun 19, 2002 | 07:43 AM
Jaminak's Avatar
Thanks! That's just what I needed to know.
Old Jun 19, 2002 | 02:05 PM
1hotintegra's Avatar
Default Re: Oil Filter (ridge racer 2)
Take time to to find a flexable magnet and wrap it around the new filter casing this will stop a good portion of particle from circulating throught the engine slowing down wear on the engine.
does that really work
Adankid
Jan 1, 2009 03:12 PM
Blahblah718293
Jun 20, 2007 06:40 PM
Boilermaker1
May 3, 2005 08:32 PM
Halo
Sep 26, 2002 11:53 AM
EKB18BPR3
11
Aug 18, 2002 11:53 PM
