squeaking sound when i turn steering wheel
Old Sep 19, 2007 | 07:56 PM
LudeJdm's Avatar
Default squeaking sound when i turn steering wheel
92 prelude si
i noticed when i pulled up in my drive way when i turn my steering wheel i hear a squeaking sound coming from the front driver side wheel. i dont know what it is. but when i pulled up in my garage on the flat ground the sound went away. i havent noticed it while i drive. this wheel is bent. please help
17" c10s
eibach lowering springs
Old Sep 19, 2007 | 08:14 PM
ethereal2pt2's Avatar
Default Re: squeaking sound when i turn steering wheel (LudeJdm)
is it like a belt squeal? it might be your p/s. try opening your hood and turning the wheel while looking at the p/s pulley. mine used to do this and it'd make a squealing sound when i turned my wheel too. the p/s pulley actually stopped.
Old Sep 19, 2007 | 08:31 PM
LudeJdm's Avatar
Default Re: squeaking sound when i turn steering wheel (_darkrequiem.)
it sounds like a door squeaking..
Old Sep 19, 2007 | 10:18 PM
onyx.ram's Avatar
Check your Power steering.
Old Sep 20, 2007 | 05:39 AM
gavzter's Avatar
Default Re: squeaking sound when i turn steering wheel (onyx.ram)
ball joint
Gavz
Old Sep 20, 2007 | 06:18 AM
street_ride14's Avatar
Default Re: squeaking sound when i turn steering wheel (gavzter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gavzter &raquo;</TD></TR><TR><TD CLASS="quote">ball joint</TD></TR></TABLE>
Yup
Old Sep 20, 2007 | 07:44 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onyx.ram &raquo;</TD></TR><TR><TD CLASS="quote">Check your Power steering. </TD></TR></TABLE>
It is only usually the power steering if it always does it.
It probably is the ball joint because the thing is under more stress on the slope of the driveway and he turns to more an extreme angle to get in there than he normally would on the road.
Old Sep 21, 2007 | 01:46 PM
LudeJdm's Avatar
Default Re: squeaking sound when i turn steering wheel (mgags7)
power steering belt had a crack
swizz977
Dec 24, 2013 02:46 PM
Damon Reeves
Dec 26, 2007 03:51 PM
715_guy
Oct 18, 2006 08:55 PM
1999gs-r
Suspension & Brakes
Aug 7, 2006 08:08 AM
Mikey3000
May 9, 2006 03:58 PM
