How to fix leaking oil pan
Old Sep 19, 2007 | 07:32 PM
Spoon84's Avatar
Default How to fix leaking oil pan
Ok guys. I rebuilt my LS motor B18b with oem spec parts. I have roughly 7k on the motor so far and everything is running good. I noticed my oil pan is leaking oil only at the right corner of the pan closest to the Driver side headlight. Well i put and OEM honda gasket and gasket sealer on it and torqued all the bolts to sequence and spec. Still leaks!!! It almost looks like its coming from a few of the bolts on the pan. It just drops occationally. The pan is not bent or damaged.. how should i go about fixing this.. Any help is appreciated!
Old Sep 19, 2007 | 07:43 PM
sleepswithnoise's Avatar
Default Re: How to fix leaking oil pan (Spoon84)
I know its probly a pain in the a$$ but, id drop the pan and get another gasket assuming maybe it was defective or your torque wrench is defective. Honestly it sounds like an over tightning problem to me. Beyond that, i dont know.
Old Sep 19, 2007 | 09:13 PM
vteczone's Avatar
just inspect carefully where the leak from again.. it might be from the crank oil seal.
im not saying it is,but worth a try.
GsrRussell
May 13, 2008 01:23 PM
6E LUDE
Oct 19, 2005 06:23 PM
garados
Jul 18, 2004 04:59 PM
deconstruct
Jun 18, 2004 01:00 PM
htownteg
Jan 30, 2004 07:15 PM
