headlight grounds?
Old Sep 19, 2007 | 05:52 PM
DADADAAAMN's Avatar
Default headlight grounds?
i just joined the crx club again and i just ran into my first big problem... it seems that my whole passenger side headlight/highbeam/bumperlights/cornerlight ground are all bad... i tried to find where the main ground is but can't seem to locate it. it's like spaghetti. would it be okay if i just grounded all the grounds for my whole pass. side lights onto my chassis or do u guys know where to check for the main ground? need help asap please!!!! thanks in advance!
Old Sep 19, 2007 | 05:56 PM
Pee Wee's Avatar
Default Re: headlight grounds? (DADADAAAMN)
dont they ground on the radiator support or somewhere around there? i dont know for sure
Old Sep 19, 2007 | 07:07 PM
The_Undertaker's Avatar
75.168.105.221
The grounds for the headlight is by the air intake cleaner buy corner lens its yellow with a metal hinge that bolts to the chassis. It has 7 wires running to the ground for the passenger side. Same goes for the drivers side there is another yellow ground box near the windshield washer bottle and by corner lens. it has 7 wires running to it. The symtoms are dimmed headlights poor ground. too much resistance in the circuit.
Old Sep 19, 2007 | 07:29 PM
DADADAAAMN's Avatar
thanks. yeah. i actually just found it. that little box was unplugged. thanks for the help though guys. knew i could count on H-T!
pliskin679
Jan 27, 2013 03:40 PM
railsman
May 1, 2007 07:36 PM
Threads
Aug 8, 2005 04:06 PM
WANARUNM
Nov 30, 2004 06:39 PM
JDMlyfestyle
Dec 2, 2003 08:25 PM
