89 civic oil burning?
Old Sep 19, 2007 | 04:16 PM
Big red89's Avatar
Default 89 civic oil burning?
Hello all I am new to this forum and have a ? to ask. I have an 89 honda civic 1.5 w 5 speed tranny dx.It has 177k miles on her and still runs great. They only problem is that is goes through oil. It doesnt smoke or leak any oil.Is there any way I can check to see if the valves need to be replaced or maybe the rings. Is this common for this motor?Would it be easier to replace the motor with an attarco motor. Looking for some options for my new honda.Any info would help
Old Sep 19, 2007 | 04:17 PM
Jonknee's Avatar
Default Re: 89 civic oil burning? (Big red89)
What's an attarco motor?
Old Sep 19, 2007 | 04:19 PM
The_Undertaker's Avatar
75.168.105.221
What's up Noob Welcome to H-T. The 1.5 is going through oil. May be time to rebuild it. Do you want to do this. There is a DIY thread to rebuild the d15. It would be easier to replace motor what is your goal for power or fuel ecomony.
Old Sep 19, 2007 | 04:22 PM
CRX Toad's Avatar
Default Re: (1988hondacrxsiR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988hondacrxsiR1 &raquo;</TD></TR><TR><TD CLASS="quote">What's up Noob Welcome to H-T. The 1.5 is going through oil. May be time to rebuild it. Do you want to do this. There is a DIY thread to rebuild the d15. It would be easier to replace motor what is your goal for power or fuel ecomony.</TD></TR></TABLE>
Wow, you answered nothing.
Big red89
You can do several test such as compression or leak down. However it does sound like you have either a issue that will require some type of work to be done on the motor. How much oil are you going through? Do you have any smoke coming out the back?
Old Sep 19, 2007 | 04:33 PM
thesmogman's Avatar
You might want to check your PCV valve. If it sticks it can suck the oil right out of it. I lost a quart in 50 mi. because I tried to clean it.
Don't clean it just get a new one.
Old Sep 19, 2007 | 04:44 PM
Jonknee's Avatar
Default Re: 89 civic oil burning? (thesmogman)
are you sure it doesnt smoke? have u had someone drive behind u
Old Sep 19, 2007 | 04:58 PM
Big red89's Avatar
It burns about a 1/4 of a quart every 144 miles. I am looking for fuel economy. I just purchased it and it looks like it has a brand new pvc valve in it. It passed smog with no problem but it does have small black water droplets comming out of the exaust when I start it up. Its like condensation comming out the tail pipe but black almost like its running rich but still get 40 mpg. Once it warms up it stops.
Attarco motor is a used japanese motor with 30k miles on it.
Old Sep 19, 2007 | 06:25 PM
boosted91crx's Avatar
Wow a guy with 40 post calling some one a noob... any way have you been under the car and checked the pan gasket and main seals? 1/4 quart is a decent amount and if its leaking there will be signs of it under neath for sure, also you dont have to see smoke for it to be burning a little oil. 177k is getting up there on miles more so if the car was reved hard often. I wouldnt think the rings would be suspect at this point i would suspect valve guides and or seals. do a cmpression and leak down test for giggles any way.
Old Sep 19, 2007 | 06:48 PM
Jonknee's Avatar
Default Re: 89 civic oil burning? (boosted91crx)
A noob calling a noob a noob, lmfao wtf is going on here.
Old Sep 19, 2007 | 06:49 PM
Big red89's Avatar
Ok I know how to do a compression test but I dont know how to do a leak down test. Can you explain to me on how to do that. The car leaks only a tiny bit of oil out of the pan.Still very dry underneath. Every time I park it I dont see any oil on the ground.Thank you for all the help by the way.
Old Sep 20, 2007 | 02:47 PM
Big red89's Avatar
bump
Old Sep 20, 2007 | 02:54 PM
75.168.105.221
Read this it is very descriptive http://www.geocities.com/dsmgr...n.htm
Old Sep 20, 2007 | 03:08 PM
atarigamer01's Avatar
"What's up Noob Welcome to H-T. The 1.5 is going through oil. May be time to rebuild it. Do you want to do this. There is a DIY thread to rebuild the d15. It would be easier to replace motor what is your goal for power or fuel ecomony."
Its just a car forum, theres others online as well...get a life.
Old Sep 20, 2007 | 03:10 PM
janz3n's Avatar
old hondas always burn oil.. even a japanese one will. my sohc zc burns a tiny bit.. but not enough to refill between oil changes..
Old Sep 20, 2007 | 03:28 PM
juanchoenuncrx's Avatar
* B A N N E D *
is even better to get b16 than rebuilding the engine it will cost more to rebuild or get another d15 i can find you one for 400$ no tranny
Old Sep 20, 2007 | 04:43 PM
Big red89's Avatar
I will try a compression test on my day off and see where I am at. I check the oil every day because of the amount of miles I put on my vehicle. She gives me great gas mileage and keeps on going. The only reason I want to get another motor is because I do put on an enourmous amout of miles on my cars and want to make sure I have a reliable non burning vehicle. Thank you guys for all the help. (just a thought) What would an easy swap be as far as wireing and boltin up with only no or little modification.
jdmsoljah
Sep 30, 2009 01:22 PM
HCivicSi23
11
Sep 17, 2007 05:49 PM
standbackimapro
25
Jul 9, 2007 11:34 AM
joanmurt
Oct 18, 2005 08:05 AM
Asway
14
Aug 19, 2004 11:15 AM
