anyone use this cast ebay mani?? d series
im thinkin of tryin it.. its looks similar to the meutek one i used to have for a b series .. i ususally get the cheap ss auto ones and re weld it all but this looks like a better choice.. i dunno about wastegate placement though
i have used one and i ported out the wastegate outlet cause it was smaller then the opening in the wastegate. it held boost fine and i never had any problems with it.
you have a pm.
you have a pm.
that really isn't an ideal placement for the wastegate and will probibly creap in most cases. look into a some other SS manifolds, if they are quality you shouldnt need to worrk about cracking and such and will still last quite a while...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs »</TD></TR><TR><TD CLASS="quote">i was more worried about wastegate and hood clearance issues.. do u think it would hit? </TD></TR></TABLE>
No you will be fine. At most the gate will sit flush with the top of the Valve Cover but I doubt it will even reach that point.
sheBangZ
Oct 21, 2016 04:36 AM
