stiff shifting
Old Sep 19, 2007 | 11:24 AM
Frstyl838's Avatar
Default stiff shifting
i have a short shifter on my 99 civic si coupe. it is a really short shift, but i hate having to go into 2nd before i go into first or 5th before i go into reverse. i have to do that or push hard as hell to get it into the gears. i was told by a couple of people it might be hitting the transmission. should i just switch it out with a B&M dual bend short shift, or have it looked at? i still want to keep the really short shifts though
Old Sep 19, 2007 | 11:57 AM
LowTEC SaiMike's Avatar
Default Re: stiff shifting (Frstyl838)
Ive had a friend with a b and m and its very stiff also for some reason , i would recommend the skunk 2 short shifter , that shifter is smooth through out all the gears
Old Sep 19, 2007 | 12:03 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frstyl838 &raquo;</TD></TR><TR><TD CLASS="quote">i have a short shifter on my 99 civic si coupe. it is a really short shift, but i hate having to go into 2nd before i go into first or 5th before i go into reverse. i have to do that or push hard as hell to get it into the gears. i was told by a couple of people it might be hitting the transmission. should i just switch it out with a B&M dual bend short shift, or have it looked at? i still want to keep the really short shifts though</TD></TR></TABLE>
don't listen to the "people" that told you it's hitting the tranny. that is the most ridiculous thing i have ever heard, and quite impossible. the reason you have to do all that unnecessary shifting is because your shifter is too short.
i recommend a B&M shifter (straight-no bends) f you want it to be stiff, along with some es bushings.
Old Sep 19, 2007 | 12:05 PM
LaosGuySi's Avatar
sifu pai mei
have you tried changing the bushings?
Old Sep 19, 2007 | 12:07 PM
Frstyl838's Avatar
no i have not changed the busings i'll try that or take a look at that though. is the b&m still gonna be short but not to stiff where i have to do what i'm doing now
Old Sep 19, 2007 | 12:09 PM
philosofy1's Avatar
Default Re: (Frstyl838)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frstyl838 &raquo;</TD></TR><TR><TD CLASS="quote">no i have not changed the busings i'll try that or take a look at that though. is the b&m still gonna be short but not to stiff where i have to do what i'm doing now
it is shorter than a oem one, but not as stiff as yours. even if you add the bushings, it'll be not so much stiff but firm. i still recommend you swapping out your current one.
Old Sep 19, 2007 | 12:22 PM
gsxr1k05's Avatar
i had the same stiff problem, but it was due to the trans being off angle a bit.
Old Sep 19, 2007 | 12:58 PM
tei344's Avatar
Default Re: (gsxr1k05)
I just recently put a pace setter short throw in my car with an energy suspention bushing kit. It was stiff at first. but it losened up. you could have tightened the connecting rod too much so it's squeezing the shirter. just a guess.
Old Sep 19, 2007 | 01:09 PM
biggishjay's Avatar
i have the b&m short shifter on my 92 si and it works great.also had the same one on my 97 coupe back in the day.
ProjectCD5
Feb 21, 2006 11:55 PM
scrap1ngsr
Apr 4, 2005 10:31 AM
ketchup
17
Aug 26, 2004 08:42 AM
icon_race_eg
13
Jan 18, 2004 04:40 PM
SOHC_MShue
Jun 20, 2002 02:44 PM
