DOHC ZC + Nitrous anyone?
Old Sep 19, 2007 | 09:51 AM
djmesican's Avatar
Default DOHC ZC + Nitrous anyone?
anyone around running nitrous on their ZC? how big of a shot are you running with it? what kind of plugs are you running? have you done anything to the motor for it? i got a Zex kit yesterday for cheap and figured i could run a small jet on the ZC and see how it handles it. (that 4spd kills me) just wanting to see who's all running nitrous on their ZC and seeing how well the motor handles it. thanks in advance.
Omar
Old Sep 19, 2007 | 02:46 PM
STREETWERKZ's Avatar
Default Re: DOHC ZC + Nitrous anyone? (djmesican)
i had this setup in like 1999-2000.
60 shot zex kit. ngk 7s spark plugs. pulled pretty hard from what i remember. it was quick for back then.
Old Sep 19, 2007 | 02:57 PM
cticknor666's Avatar
Yea i ran a 75 shot on my zc for quite a while. 1 step colder plugs was all i did.
Old Sep 19, 2007 | 02:59 PM
Default Re: (cticknor666)
back then i was scared to run a higher shot.
before this setup, i ran a d16z6 on a 50 dry.
and after, 100 shot direct port on a B16. <---- perfect.
Old Sep 19, 2007 | 03:23 PM
The_Undertaker's Avatar
75.168.105.221
Be careful with NOS man I had NOS in my stock a6 and it blewn up because I shot at 85 and for a week it was cool. Until i went at the track and loss all.
Old Sep 19, 2007 | 04:13 PM
gator88's Avatar
Default Re: (1988hondacrxsiR1)
newb, streetwerkz knows his ****. sit back and learn who knows there **** around here and who doesnt before you get skooled. tell us ur setup details that blew ur motor?!
Old Sep 19, 2007 | 04:22 PM
Default Re: (gator88)
probably a dry 85 shot, stock spark plugs, and advanced timing.
yeah, recipe for disaster.
nitrous is TOTALLY SAFE! you just need to know how it works.
keep in mind, the military used nitrous oxide on airplanes during world war I and world war II. if its safe in the air, its safe on the ground. just add the proper spark temperature and the proper amount of fuel.
Old Sep 21, 2007 | 04:40 AM
djmesican's Avatar
bad ***. what plug should i go with street? i plan on running a 30 - 35 shot. if not a 50 shot our around there. i don't want to push this ZC that hard as this is just my beater car. the jet i have on it now is a 65 shot but i haven't installed it. thanks for all the help street.
Omar
Old Sep 21, 2007 | 08:59 AM
.Grimace's Avatar
footwork mastery
Default Re: (STREETWERKZ)
x2
friend ran a 100 zex wet shot on his d16z6 for i don't even know how long and never had a problem.
Old Sep 22, 2007 | 07:38 PM
djmesican's Avatar
what spark plugs are best to run? i also have the msd box (-6al i think) w/ the cap, rotor, and ignition coil. it's alright to run this w/ nitrous right?
Old Sep 22, 2007 | 07:44 PM
Default Re: (djmesican)
ngk 7s is what i always use. i actually just bought a dry setup for our other broject car and plan on trying out the zex plugs. i think those are just ngk 7s, but i cant be certain until i get them.
get one step colder than your stock plugs, retard the timing 2 degrees on a 30-35 shot, and keep an eye on your plugs after every hard run.
Old Sep 22, 2007 | 08:28 PM
C_R_X_V_T_E_C's Avatar
i ran a 75 shot dry zex kit, 2 step colder ngk plugs. pulled real hard... not a problem in the world. if you get a good kit from a dealer or off of a good website it will come with instructions for how far to retard the timing. its really easy to install. and if you only plan on running a 50 shot, you shouldnt have anything to worry about.
Old Sep 29, 2007 | 01:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">ngk 7s is what i always use. i actually just bought a dry setup for our other broject car and plan on trying out the zex plugs. i think those are just ngk 7s, but i cant be certain until i get them.
get one step colder than your stock plugs, retard the timing 2 degrees on a 30-35 shot, and keep an eye on your plugs after every hard run. </TD></TR></TABLE>
BTW, retarding the timing that much is just to ensure it's still safe. when infact, that is really a small shot and you could probably run stock timing. (more power)
Old Sep 29, 2007 | 01:47 PM
rd91sib18c5r's Avatar
I ran the same kit on a ls moter with a 75 shot had no problems
the 55 should be no problem for that motor just retard the timing
and hang on, I'm using the same kit on my type r swap now and
when it's on it's 1 sec faster in the 1/4 mile. Have fun
Old Sep 29, 2007 | 03:02 PM
Deetz's Avatar
Crazy Honda Guy
From 1996-2000 i ran my dohc zc on a 75 shot zex kit. Mods were I/H/E, walbro fuel pump, B&M fuel regulator, one step cold er NGK plugs, MSD ignition and coil, lightened flywheel and DF clutch.
My best run was a 13.7@101mph....sticky tires helped a lot!!!
Old Sep 29, 2007 | 09:15 PM
x4thGenCafe's Avatar
OF THE KINGS
Default Re: (Deetz)
y0 ! Streetwerkz . . you tryin to let me in on some helpful info on spray and my Japanese B16A ??
DmcL
21
Jan 30, 2007 12:09 PM
BseriesHatch
11
Apr 27, 2004 06:19 PM
BseriesHatch
Dec 12, 2002 12:21 PM
91HATCH
17
Feb 13, 2002 03:17 AM
