swapping in a gsr am i missing anything?
Old Sep 19, 2007 | 06:43 AM
sohcdestruction's Avatar
Default swapping in a gsr am i missing anything?
ok well me and another member of my car club built this gsr motor well more of peiced to gether anyway am i missing anything on my list of haves and need to buys?? any tricks on parts i can use to save me some money? we are wanting to put this in our 93 del sol
HAVES
complete head
complete block(both head and blck have been assembled)
gsr tranny(has been bolted up with new clutch and flywheel)
alternator (intalled)
all pulleys etc..
motor is complete
obd1 Gsr integra wiring harness
shift linkage(came out of a bseries swapped sol but no stabilizer)
obd1 jdm gsr ecu
NEEDS
Motor mounts(i can use stock integra ones right??)
stabilizer
slave cylinder(or will the sohc one work?)
axles
am i missing anything ????
can i substitiute any helps appreciated i searched but all i got was how to threads i need more of a shopping list lol
Old Sep 19, 2007 | 06:47 AM
instrument's Avatar
yes you can use integra mounts on an integra motor.
Old Sep 19, 2007 | 06:50 AM
crazyguy's Avatar
Default Re: (instrument)
and yes u can reuse sohc slave clutch cylinder because i am using it with my b16a swap
Old Sep 19, 2007 | 06:58 AM
Default Re: (crazyguy)
ok cool anything else thanks for the help guys really appreciate it heres some pics of the sol how we got it
Old Sep 19, 2007 | 07:09 AM
Default Re: (sohcdestruction)
will the stock del sol si linkage and stabilizer work??? this car had vtec already before prev owner pulled the motor after he wrecked it (its been mostly fixed lol) just asking cause i didnt know the sohc slave would work lol thanks again
Old Sep 19, 2007 | 07:12 AM
gsxr1k05's Avatar
the del sol was a b series prior to wrecking then yes it should work.. someone back me on this..
Old Sep 19, 2007 | 07:15 AM
Default Re: (gsxr1k05)
no it was a d16z6 stock si motor if im not mistaken
someone just said that i need a delsol vtec linkage??? the sohc had vtec does that mean the sohc linkage will work i wouldnt think so but again that is why im asking
Old Sep 19, 2007 | 07:28 AM
vestalfootball72
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcdestruction &raquo;</TD></TR><TR><TD CLASS="quote">no it was a d16z6 stock si motor if im not mistaken
someone just said that i need a delsol vtec linkage??? the sohc had vtec does that mean the sohc linkage will work i wouldnt think so but again that is why im asking</TD></TR></TABLE>
there was a del sol VTEC model not to be confused with the SI.
SI-d16z6
vtec- b16a2/3
Old Sep 19, 2007 | 07:31 AM
Default Re: (vestalfootball72)
oh ok see im a ef guy lol i never even looked into delsols im jsut helpin this guy build it
so where can i find this linkage/stabilizer or a linkage/stabilizer that will work
i found a linkage out of a gsr swapped del sol here in town for 35 bucks but i still need the stabilizer
Old Sep 19, 2007 | 08:02 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcdestruction &raquo;</TD></TR><TR><TD CLASS="quote">oh ok see im a ef guy lol i never even looked into delsols im jsut helpin this guy build it
i found a linkage out of a gsr swapped del sol here in town for 35 bucks but i still need the stabilizer</TD></TR></TABLE>
The del sol shifter rod itself is longer (not the shifter you hold...the shifter rod under the car). i believe the stabilizer is the same size as the other B series setups.
Old Sep 27, 2007 | 10:54 AM
Default Re: (B serious)
bump
Old Oct 1, 2007 | 06:57 AM
morning work bump
White_EK49
Dec 17, 2007 04:13 PM
-Justin-
Jul 24, 2006 06:57 AM
GSR-T-
Mid-Atlantic (Sales)
Jul 28, 2005 06:27 AM
92B20GSR
Mar 27, 2004 01:25 PM
oem
Sep 12, 2002 09:30 AM
