Head Gasket Question
I have a 92 H23 boosted prelude. Running 15psi on Prof tune. ARP Head studs built bottom end. I was running a Civic SI Half Radiator and every time I go into boost car will run hot and overflow tank will fill up with antifreeze. Ive since put a Koyo full size radiator in car and havent got to test it alot but now Im still getting a little antifreeze sitting on top of overflow tank. No where near as much as before. Is this the headgasket going out or maybe just blowing back through the overflow inlet. I have a Compression tester but how do you do a leak down test. Any help would be appreciated.
Thanks Pat
Thanks Pat
check your sleeves.... you probably have a sleeve sinking or raising... that sounds exactly like wat happened to me, no signs or a cracked head, bad/broken gasket, nothing... it was the sleeves, one sunk... when you get a sleeved engine too hott thats what tends to happen...
You guys dont think it was from using too small of a radiator? The overflow only overflows when I come into boost. On the small radiator.. I dont know for sure If it will do the same with the new radiator. I will have to find out. But I can drive the car around just fine as long as I dont come into boost with the small radiator. No Overflow problems at all. I appreciate all the help.
Pat
Pat
Well, the head gasket could be leaking boost pressure into the coolant system and pressurizing it too much......or it could be from the smaller inadequate radiator like you said. Different things to check out....
92accord1988
Apr 26, 2017 05:06 AM
5thgencivic
Mar 25, 2003 12:46 PM
