boring?
Old Sep 19, 2007 | 03:21 AM
chngeovr99's Avatar
Default boring?
i was wondering if boring out my block which is a b18c1 to a 2.0L is worth all the dolla's? im build my block n head up this winter and need to know if i get that done will it be to my advantage to speed it.. and what sleeves are people running that do it. any shops on here have a privefor something like that.
Old Sep 19, 2007 | 05:12 AM
98vtec's Avatar
moderator emeritus
Default Re: boring? (chngeovr99)
no replacement for displacement.
Old Sep 19, 2007 | 05:23 AM
mgags7's Avatar
You'll have trouble just boring the cylinders out to get that much displacement. Look into a longer stroke crank.
Old Sep 19, 2007 | 05:34 AM
b19coupe's Avatar
It's worth it. Far too many people with the wrong bolt ons. At least with a 2 liter it's easier to hit 200 WHP with a cheap knock off header, knock off cams, a knock off intake manifold and a head ported in a buddies garage
Old Sep 19, 2007 | 05:41 AM
98vtec's Avatar
moderator emeritus
Default Re: boring? (b19coupe)
backyard tuning ftw
Old Sep 19, 2007 | 08:08 AM
gofastmobile's Avatar
definately worth it if you are looking to get some more torque for city driving and that last bit of power that you are looking for. def. sleeve though.
Old Sep 19, 2007 | 11:22 AM
b20beast978's Avatar
like they say theres no replacement for displacement. I just bought some 85mm golden eagle sleeves with some 11:5 endyn pistons. If its for teh street and some ocassional strip i would go 85mm just my .02
Old Sep 19, 2007 | 11:31 AM
cartune network's Avatar
Default Re: (b20beast978)
if ur gonna do it i would go with 84.5mm pistons so ull have room to bore when u need a rebuild. if u want more torque though i would reccomend getting a brian crower stroker kit. u can get a 95mm or a 92mm stroke which will inturn make u more torque than sleeving and boring but if you do both ull make some really good power. i have seen over 245whp and gobs of torque on pump gas with 84mm pistons and a 95mm stroke.
HERN39
Dec 9, 2015 05:05 AM
thesoundofturbo
Apr 30, 2008 03:57 AM
SSS2000
Aug 26, 2004 01:45 PM
turbo*s2k
Feb 6, 2004 12:41 PM
black-hatch
Jan 5, 2003 01:17 PM
