Wiring tango
Old Sep 19, 2007 | 02:35 AM
MidShipCivic's Avatar
Default Wiring tango
I'm doing a OBD-1 B18b1 swap into a what appears to be an 88 that currently has a D16Y7. Vin says ED8 which means this car originally had a 1.5L.
I do not want to do OBD-0 because I already have an OBD-1 GSR engine harness and injectors.
What I want to do exactly is use these junction connectors here with the GSR OBD-1 harness by just re pinning them, and yes I'll be using and re pinning ecu connectors also.
I've downloaded several CRX service manuals and none show the model that I'm working on and they dont match the 1.5L Harness colors where can I get this info?
Old Sep 19, 2007 | 03:04 AM
K2e2vin's Avatar
That's a **** load of work because you have to deal with both sides(the main harness on the driver side also).
I forgot what diagram I used but took me awhile to gather all the information; I pretty much just followed the wires or looked up the colors. I ended up just making a driver side "conversion harness", then cut main harness from a EG EX(from engine connectors to ECU, cutting out the stock one), then just soldiering in the corresponding wires that were left on the main harness.
Modified by K2e2vin at 9:02 AM 9/19/2007
Old Sep 19, 2007 | 03:53 AM
DenzComp's Avatar
Good Luck.
Old Sep 19, 2007 | 06:41 AM
Default Re: (K2e2vin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K2e2vin &raquo;</TD></TR><TR><TD CLASS="quote">
I forgot what diagram I used but took me awhile to gather all the information; I pretty much just followed the wires or looked up the colors.</TD></TR></TABLE>
Thats pretty much what I gotta do I guess.
Old Sep 19, 2007 | 07:43 AM
spastik's Avatar
Default Re: (MidShipCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic &raquo;</TD></TR><TR><TD CLASS="quote">
Thats pretty much what I gotta do I guess.</TD></TR></TABLE>
thats what i did when i did my b16 swap. i used the jdm harness because the dx harness was trash. i spent a week tracing wire and depinning-repinning, and or soldering-heatshrinking everything. in the end i was a lot happier.
i used the honda shop manual and the b16 suppliment for mine.
Old Sep 19, 2007 | 08:14 AM
dem0nk1d's Avatar
get a obd1 engine harness, and use a obd1 jumper harness. the jumper hearness will have leads that come off that have knock, o2, v-attack, etc.
Old Sep 19, 2007 | 08:18 AM
Default Re: (dem0nk1d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d &raquo;</TD></TR><TR><TD CLASS="quote">get a obd1 engine harness, and use a obd1 jumper harness. the jumper hearness will have leads that come off that have knock, o2, v-attack, etc.
I'm obviously not getting a jumper if I'm doing this...
Old Sep 19, 2007 | 08:26 AM
RMX_EF9's Avatar
I believe hondatech.info May have what your looking for, scope around in the manuals ... I grabbed one off of there for mine !!!
Old Sep 19, 2007 | 08:38 AM
Rywire's Avatar
Default Re: (RMX_EF9)
your doing it the hard way
Old Sep 19, 2007 | 12:11 PM
Default Re: (Rywire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rywire &raquo;</TD></TR><TR><TD CLASS="quote">your doing it the hard way</TD></TR></TABLE>
Oh yeah and whats the easy way?
Old Sep 19, 2007 | 12:48 PM
Under Con. CrX's Avatar
lol he wants you to send it to him you know rywire right the do wire harness for a decent price and great quality thats what he means
Old Sep 19, 2007 | 12:59 PM
Default Re: (Under Con. CrX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Under Con. CrX &raquo;</TD></TR><TR><TD CLASS="quote">lol he wants you to send it to him you know rywire right the do wire harness for a decent price and great quality thats what he means </TD></TR></TABLE>
How am I suppose to be skillful and resourceful if I don't learn to do it myself?
Old Sep 19, 2007 | 01:28 PM
hell if i know ask him not me
Old Sep 19, 2007 | 01:57 PM
STREETWERKZ's Avatar
this man speaks the truth.
at least call Ryan and see what he has to say. he might just walk you through the 'hard way'
Old Sep 19, 2007 | 03:01 PM
Rywire's Avatar
Default Re: (STREETWERKZ)
ill give you free info over pm, im not trying to sell you anything you dont want...
Old Sep 19, 2007 | 03:14 PM
The_Undertaker's Avatar
75.168.105.221
What's up Rywire. I saw your video on youtube with the K20a in the crx. Amazing stuff.
Old Sep 19, 2007 | 03:18 PM
atarigamer01's Avatar
Default Re: Wiring tango (MidShipCivic)
You should go to rywire.com and let them do it for you. It may cost some money but atleast youll know its done right. Im doing a d15b vtec swap. I used to have a d15b2 which was obd0 and dpfi. The d15b vtec is obd1 and mpfi. You basically send them both wiring harnesses from each engine and they mix them together so to speak to make one wiring harness for your new motor. I would go to rywire.com
Old Sep 19, 2007 | 03:19 PM
Default Re: Wiring tango (atarigamer01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atarigamer01 &raquo;</TD></TR><TR><TD CLASS="quote">You should go to rywire.com and let them do it for you. It may cost some money but atleast youll know its done right. Im doing a d15b vtec swap. I used to have a d15b2 which was obd0 and dpfi. The d15b vtec is obd1 and mpfi. You basically send them both wiring harnesses from each engine and they mix them together so to speak to make one wiring harness for your new motor. I would go to rywire.com</TD></TR></TABLE>
I got the point but I'm not going to send anything I'm doing this myself.
Modified by MidShipCivic at 8:27 PM 9/19/2007
75.168.105.221
Yeah in Rywire we Trust. Good harness for your all needs.
Old Sep 19, 2007 | 03:21 PM
I got the point but I'm not going to send anything I'm doing this myself.</TD></TR></TABLE>
so, call him. he'll talk you through it so you can do it yourself.
Old Sep 19, 2007 | 03:24 PM
75.168.105.221
He's website is rywire.com. Email him or call. Good stuff.
Old Sep 19, 2007 | 04:35 PM
Welp since the ED8 service manual tells me little about what junction it goes to accurately enough I :
Cut the D15's harness up. I'll get back here with some questions for sure.
Old Sep 19, 2007 | 07:02 PM
90sedan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidShipCivic &raquo;</TD></TR><TR><TD CLASS="quote">Welp since the ED8 service manual tells me little about what junction it goes to accurately enough I :
Looks like fun
for diy
Old Sep 19, 2007 | 07:27 PM
Default Re: (90sedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90sedan &raquo;</TD></TR><TR><TD CLASS="quote">
Looks like fun
for diy</TD></TR></TABLE>
Thanks. What sensor is this connector for its a yel/green and it goes under the distributor.
Old Sep 19, 2007 | 09:07 PM
90sedan's Avatar
Its for the fan switch.
