Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Si Sedan Wheel Question?
Old Sep 18, 2007 | 08:24 PM
phatsi's Avatar
Default Si Sedan Wheel Question?
Does anyone know if you can put a 16" wheels on the Si sedan's? I know the rotors and calipers are larger than the EX sedan but can this be done? Only reason is I have new snows on 16" wheels that are the perfect set up if it can be done. Thanks!
Old Sep 18, 2007 | 08:29 PM
Tokyosmash!'s Avatar
Tickle-shits
Community Builder
Community Influencer
Default Re: Si Sedan Wheel Question? (phatsi)
They will fit assuming the offset is reasonable.
Old Sep 19, 2007 | 11:34 AM
phatsi's Avatar
Default Re: Si Sedan Wheel Question? (Tokyosmash!)
same as stock offset......thanks for the info.....
Old Sep 19, 2007 | 11:56 AM
iamtwan's Avatar
whats the biggest size you can fit on the si in general?
Old Sep 19, 2007 | 12:01 PM
Type X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatsi &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know if you can put a 16" wheels on the Si sedan's? I know the rotors and calipers are larger than the EX sedan but can this be done? Only reason is I have new snows on 16" wheels that are the perfect set up if it can be done. Thanks!</TD></TR></TABLE>
That is very vague.
16" rims will fit on the Si, however there are some models that are designed differently & will NOT fit,
but the majority of 16's will be fine
ie. type r wheels, ex sedan wheels, rsx type s 02-04's etc etc
Old Sep 19, 2007 | 10:03 PM
phatsi's Avatar
Default Re: Si Sedan Wheel Question? (Type X)
yeah, good point. they are off an 06 ex so i think they should be fine....
Old Sep 19, 2007 | 10:04 PM
COMplex.'s Avatar
Default Re: Si Sedan Wheel Question? (iamtwan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iamtwan &raquo;</TD></TR><TR><TD CLASS="quote">whats the biggest size you can fit on the si in general?</TD></TR></TABLE>
16 looks a bit small, 17, 18 are most common, and 19, 20+ is just stupid looking, but they fit.
Old Sep 19, 2007 | 10:26 PM
iamtwan's Avatar
Default Re: Si Sedan Wheel Question? (COMplex.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by COMplex. &raquo;</TD></TR><TR><TD CLASS="quote">
16 looks a bit small, 17, 18 are most common, and 19, 20+ is just stupid looking, but they fit.</TD></TR></TABLE>
yeah i was wondering why they were talking about 16s 17&18's gotta look way better
danthemang3
Sep 11, 2008 03:40 PM
Jacen
May 21, 2007 05:54 PM
nello a.
Honda Civic (2001 - 2005)
Jun 15, 2006 09:07 PM
06CIVICCOUPE
May 20, 2006 12:13 PM
