Temp. gauge on my cluster jumps sparatically
Old Jun 17, 2002 | 12:35 PM
ITR1071's Avatar
Default Temp. gauge on my cluster jumps sparatically
Temp. gauge on my cluster jumps from norm operating temp to "H". It will then go back down, I can't figure anything that could cause it to just change the way it does.
Old Jun 17, 2002 | 12:53 PM
ITR1071's Avatar
Default Re: Temp. gauge on my cluster jumps sparatically (undercoverSI)
anybody???
Old Jun 17, 2002 | 02:05 PM
KoRE's Avatar
thermostat....blown headgasket, check your cooling system
Old Jun 17, 2002 | 02:07 PM
Spade's Avatar
Could be a faulty connection/ground.
Unless it isn't really a jump and it is a smooth transition to H and then back down.
If it is the later then I would assume that your water pump is on it's way out.
Old Jun 20, 2002 | 12:40 PM
ITR1071's Avatar
Default Re: Temp. gauge on my cluster jumps sparatically (Spade)
I will check all of my grounds,
thanks Spade.
VTEC_Honda
Apr 14, 2010 12:43 AM
rabbid sir
Jul 2, 2007 10:17 PM
jdmxsoles
Jun 11, 2007 12:56 PM
Rhetoric
Sep 14, 2001 06:55 PM
