Possessed Fan?
Old Sep 18, 2007 | 06:26 PM
95silverluder's Avatar
Default Possessed Fan?
My fan turns on after my car is completely turned off. Is this suppose to happen or is this a problem?
Old Sep 18, 2007 | 06:29 PM
Acidcrakker's Avatar
Default Re: Possessed Fan? (95ludeRiDeR)
Its normal, my car does it too. Mostly when Ive beed driving it for awhile. Like I go into a store to buy something and come out and its still running. Now if you come out in the morning and havent driven it since the night prior then you have a problem.
Old Sep 18, 2007 | 06:32 PM
Default Re: Possessed Fan? (acidcrakker)
haha alright thanks, its been happening ever since I got the car and my friend said it wasnt normal, just wanted a 2nd opinon.
Old Sep 18, 2007 | 06:48 PM
mattmw88's Avatar
Are you sure this is supposed to happen when your keys are out of the ignition? From what I gather (and it's possible I'm wrong), if, after you put the keys in the off position (completely off& out of the ignition), it's possible that it could be the ignition switch.
I would agree though that if it never stays on very long and you don't have power to other accessories in the car that it is probably just the car cooling itself down.
Good luck...
Old Sep 19, 2007 | 04:42 AM
mgags7's Avatar
preludefien's fan was turning on <u>when</u> you took the keys out, and it would stay on until you pulled the relay out.
turned out he had the coolant sensors hooked up wrong, fixed the problem. do you have CEL 6 by chance?
5pointer
Jun 17, 2012 09:40 AM
snowman2876
10
May 14, 2010 10:20 AM
dropculture
Feb 5, 2008 02:10 PM
hangac1093
Jan 26, 2006 06:28 PM
cr00klyn718
Sep 30, 2002 09:27 PM
