please HELPPP car pulls to left hardddd
Old Sep 18, 2007 | 03:39 PM
eflshatch's Avatar
Default please HELPPP car pulls to left hardddd
hey i have a 90 si hatch ls swap and im lost on how to fix a problem i have
first off to say the back right shock and spring setup is either stripped or some other problem cuz the adjustment brackets to raise and lower the car is sitting, bottomed out prolly stripped at the botttom of the shock leaving the spring loose and doing nothing
im not sure if this is the cause but i doubt it
my car when not holdiong the steering wheel on the slightest touch of acceleration jerks hard to the left side like str8 into the devider type of hard
im not sure if i need a camber kit or i ahve a bent control arm but ive fixed a number of things on the car and this is the last main problem needed fixing. also i cant catch possi one tire spins adn other drags *** (left spins and right doesnt) unless i dump the clutch at about 6500 - 7grand
any help as soon as possible would be awesome i wanna get this banged out in the next month. lol or few days
thx in advance
-jet
Old Sep 23, 2007 | 05:00 PM
eflshatch's Avatar
Default Re: please HELPPP car pulls to left hardddd (eflshatch)
bump plz help
Old Sep 23, 2007 | 07:08 PM
danmdevries's Avatar
Radius rod broken?
Bushings on LCA and Radius rods shot?
Balljoints shot?
Alignment bad?
Steering rack shot?
If it's happening under acceleration, something's happening to push your wheel backwards, which leads me to think your radius rod isn't doing its job, and the bushings on your lCA are worn (as they are on most EF's) and should be replaced
Inspect and get back to us
Old Sep 26, 2007 | 09:36 AM
eflshatch's Avatar
Default Re: please HELPPP car pulls to left hardddd (danmdevries)
will do thanks alot im ****** stressin this **** hard anyone else have any ideas?
Old Sep 26, 2007 | 10:29 AM
65stang90crx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danmdevries &raquo;</TD></TR><TR><TD CLASS="quote">Radius rod broken?
Balljoints shot?
Alignment bad?
Steering rack shot?
Inspect and get back to us</TD></TR></TABLE>
I would start here^^^
Old Sep 26, 2007 | 11:00 AM
CW-ITR's Avatar
Default Re: please HELPPP car pulls to left hardddd (65stang90crx)
Broken motor mount(s)?=bad bushing(s)
Old Sep 26, 2007 | 12:49 PM
tougetuned_ef's Avatar
take it to an alignment shop. even if you fix what ever is bent/broken, your gonna need to have it aligned. and fix that strut cause your gonna kill your self if it gives out when your driving. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eflshatch &raquo;</TD></TR><TR><TD CLASS="quote"> first off to say the back right shock and spring setup is either stripped or some other problem cuz the adjustment brackets to raise and lower the car is sitting, bottomed out prolly stripped at the botttom of the shock leaving the spring loose and doing nothing
turbojdmhatch
Suspension & Brakes
Sep 13, 2010 11:44 AM
shawndb1
Jun 6, 2010 06:27 PM
92integraVTECgsr
Suspension & Brakes
Feb 27, 2006 09:37 AM
VTECRaZeR
Jan 23, 2004 01:16 PM
