Idles too low at stop signs
Old Sep 18, 2007 | 02:42 PM
vrrodri's Avatar
Default Idles too low at stop signs
runs fine but when I stop idle drops way low and car dies sometimes. Is it the IACV? No codes, car is stock, timing is correct. No vacuum leaks. ek hatch. Only has 72k miles. D16y7 engine, new plugs, air filter, fuel filter, cleaned MAFS, and throttle plate.
Any ideas??
Old Sep 18, 2007 | 02:49 PM
mike9571's Avatar
Default Re: Idles too low at stop signs (vrrodri)
You answered your own question. More than likely its the iacv.
Old Sep 19, 2007 | 07:54 AM
stinkyfeet's Avatar
Default Re: Idles too low at stop signs (mike9571)
adjust your idle set screw. It is on your throttle body, up top. (flat head), just make sure not to strip it, as they epoxy it in, and it is very tight...
vaccume leak would cause car to idle too high.
Also, IACV could be your culprit... as it regulates air coming into the engine when throttle plate is closed.
Old Sep 19, 2007 | 08:04 AM
philosofy1's Avatar
Default Re: Idles too low at stop signs (stinkyfeet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stinkyfeet &raquo;</TD></TR><TR><TD CLASS="quote">adjust your idle set screw. It is on your throttle body, up top. (flat head), just make sure not to strip it, as they epoxy it in, and it is very tight...
Also, IACV could be your culprit... as it regulates air coming into the engine when throttle plate is closed.</TD></TR></TABLE>
the op said his idle was low, not high. and i wouldn'y suggest adjusting the idle screw. that is not the proper way to correct the situation. actually, you should never touch that screw to begin with.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vrrodri &raquo;</TD></TR><TR><TD CLASS="quote">runs fine but when I stop idle drops way low and car dies sometimes. Is it the IACV? No codes, car is stock, timing is correct. No vacuum leaks. ek hatch. Only has 72k miles. D16y7 engine, new plugs, air filter, fuel filter, cleaned MAFS, and throttle plate.
Any ideas??</TD></TR></TABLE>
before you start taking stuff apart and buying costly parts, why don't you replace the pcv valve. they run about $3 at the store and 95% of the time is the culprit.
s13hero
13
Apr 17, 2017 09:37 AM
BB1 H22A LUDE
Feb 25, 2008 01:55 PM
k_lude
Oct 2, 2006 07:25 PM
jdmCivic925
Oct 25, 2005 02:37 PM
bleebdat
Jan 7, 2003 10:52 AM
