Burned 3/4 quart from LA to San Fran and back?
Old Sep 18, 2007 | 11:46 AM
creator1322's Avatar
Default Burned 3/4 quart from LA to San Fran and back?
I wasn't driving extremely hard at all, just going about 85 - 90 there and back.
Is it normal to burn this much oil?
I have about 115,000 miles and haven't burned oil before.
Old Sep 18, 2007 | 01:34 PM
Charri's Avatar
Default Re: Burned 3/4 quart from LA to San Fran and back? (creator1322)
did you properly break in the car in the beginning?
Old Sep 18, 2007 | 02:32 PM
Default Re: Burned 3/4 quart from LA to San Fran and back? (Charri)
I know the original owner personally, and he said he did...
never put above 4,000 or 5,000 rpm till i think 10,000 miles.
that's all he could tell me about the beginning.
Old Sep 18, 2007 | 02:37 PM
pos_cd5's Avatar
no, thats not normal. most likely your rings and or cylinder walls are worn/scored. i would throw in a can of RESTORE every oil change and see if it helps.
Old Sep 18, 2007 | 02:55 PM
Default Re: Burned 3/4 quart from LA to San Fran and back? (pos_cd5)
Is it really anything to worry about at this point?
I'm assuming not to worry about it unless it gets significantly worse.
Old Sep 18, 2007 | 03:39 PM
Charri's Avatar
LA to San Fran and back is about 1000 miles. I would say its sort of bad not much really. Try the Engine Restore as stated earlier.
Old Sep 18, 2007 | 05:47 PM
accord99power's Avatar
do u see oil on your drive way?
Old Sep 19, 2007 | 08:01 AM
Default Re: Burned 3/4 quart from LA to San Fran and back? (accord99power)
No oil drive way that I can see.
I just got back Sunday from the trip, so I'm not sure quite yet.
Old Sep 19, 2007 | 01:25 PM
any smoke coming from tail pipe?
Old Sep 19, 2007 | 01:46 PM
SuShiBoiiii's Avatar
are you still burning oil during your everyday commute?
Old Sep 20, 2007 | 03:09 PM
Default Re: Burned 3/4 quart from LA to San Fran and back? (SuShiBoiiii)
I will check on everyday commute burning.
I was not previously burning oil since the beginning of July.
This is the first time I've experienced any oil burn was on this long trip.
hmm??
WIhondas
Honda CR-V & Element
Nov 2, 2011 07:22 AM
r.etheridge
21
Feb 11, 2011 07:33 PM
return_2020
Jul 31, 2005 07:33 PM
oMek
Mar 2, 2004 07:25 PM
mikeSONICGSR
Jun 16, 2002 10:48 PM
