2.5" exhaust ?
Old Sep 18, 2007 | 09:26 AM
kadidle's Avatar
Default 2.5" exhaust ?
im looking for a 2.5" for an SH. Is the skunk2 mega power a 2.5" exhaust ? idc what it sounds like bcause im going to change the muffler im just looking for any exhaust system that comes 2.5" and is pretty cheap
Old Sep 18, 2007 | 09:38 AM
Stealthbb6's Avatar
Default Re: 2.5" exhaust ? (kadidle)
Just get it done at a local exhaust shop and buy a universal muffler thats what i did only cost me $200 for the work and the piping then i got a resonator and got it put on for an extra $100 including the resonator so all together didnt even spend $300 for a 2.5 in cat-back
Old Sep 18, 2007 | 12:25 PM
kadidle's Avatar
Default Re: 2.5" exhaust ? (Stealthbb6)
yeah but was it mandrel bent tubing ?
Old Sep 18, 2007 | 12:32 PM
MLBZ521's Avatar
It's the process through which the Tubing, or Exhaust Piping, is bent.
It bends the Piping/Tubing so that it stays, say 2.5", through the bend, where Crush bent makes it smaller in the bend where it would be restrictive.
Old Sep 18, 2007 | 12:49 PM
Riptide101's Avatar
Default Re: 2.5" exhaust ? (MLBZ521)
Good luck. Haven't been able to find any after market exhaust system that comes as a kit, that is 2 1/2 piping. Thermal and greddy make some the at are 3 in but they are only for specific cars and ours isn't one of them
Old Sep 18, 2007 | 03:20 PM
switched_in_your_eye's Avatar
Skunk2 is 2.5".
Old Sep 18, 2007 | 03:30 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
3'' is gonna enable you to get the most gains.....go to a muff shop have em throw 3'' on a magnaflow muff and fire you cat and youll be fine...oh remember to get a resonator to keep the rasp tolerable
Old Sep 18, 2007 | 07:06 PM
Altilude's Avatar
Default Re: 2.5" exhaust ? (I got the CD5 Jeebies!)
go to kteller.com and get the 2.5" piping kit (stainless or mild - mandrel bent), pick a muffler and a resonator and you're golden. then get a local shop to install that (unless you can weld)
it's what's on my 4th'y - but they got kits for the 5th gen too.
Old Sep 18, 2007 | 07:37 PM
sleepyH22's Avatar
i had crush bent 2.5" exhaust to a n1 muffler but it made great power (no back pressure w/ lots of velocity)...Very loud though!!!
this was on a 94 prelude h22...and for some reason h22's with open exhaust (no resonator) sound Very raspy and pop alot.
Old Sep 18, 2007 | 09:23 PM
Ralleh's Avatar
So 2.5" and up are only really beneficial with a turbo, right?
Old Sep 18, 2007 | 09:27 PM
Acidcrakker's Avatar
Default Re: (Ralleh)
I think the Greddy sp2 piping is only 60mm wide, which is like 2.3 inches.
Old Sep 18, 2007 | 11:12 PM
98vtec's Avatar
moderator emeritus
Default Re: (switched_in_your_eye)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by switched_in_your_eye &raquo;</TD></TR><TR><TD CLASS="quote">Skunk2 is 2.5". </TD></TR></TABLE>
nope. sorry.
these companies that advertise their exhaust sizes are advertising the OD (outside diamter) of the piping, which we should all know isnt what matter. The ID is what matters.
thus, 60mm exhausts are really 2.25".
http://www.kteller.com sells piping kits.
Old Sep 19, 2007 | 12:00 AM
ek_sick's Avatar
skunk2 is an 2.5
Old Sep 19, 2007 | 11:24 AM
Xringmsp's Avatar
ive got a '97 Prelude and run an evo2 cat back exhaust with a high flow cat...2.5" all the way back and it doesnt really have a hint of rice to it lol
Old Sep 19, 2007 | 11:34 AM
Default Re: 2.5" exhaust ? (Xringmsp)
A little off topic. If the high flow cat is 2.5 and the piping is 2.25, is that really gonna matter?
Old Sep 19, 2007 | 11:38 AM
kadidle's Avatar
so i see that kteller doesnt make a full exhaust for an prelude SH, so if you tell them will they send you the pipes you need to weld up or do you have to measure eveything yourself
Modified by kadidle at 12:52 PM 9/19/2007
Old Sep 19, 2007 | 12:39 PM
Riptide101's Avatar
Evo2s are not 2.5 piping. I bought a kit and was very disappointed.
Old Sep 19, 2007 | 02:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ralleh &raquo;</TD></TR><TR><TD CLASS="quote">So 2.5" and up are only really beneficial with a turbo, right?</TD></TR></TABLE>
NO I made 201 whp and 165 tq with 3'' exhaust a modified DC sports header and a ebay intake and 45 mins of dyno tuning on a chipped p28 running crome.......there is a common misconception that the 3'' is too big for a NA motor but it's false in regards to H22s......all the 2.0 GSR doods and CRVtecs run 3'' it allows you to make the most power.......but what do i know???
Old Sep 20, 2007 | 12:07 AM
DIRTYsouthBB6's Avatar
I think that the best bet would be just to order a few mandrel bends and a large section of staright pipe from kteller.com and go to a local muffler shop with them. Even if the muffler shop doesn't have a mandrel-bender, they can just use the mandrel bends that you bring them and you're set.
Old Sep 21, 2007 | 09:27 PM
kadidle's Avatar
Default Re: (DIRTYsouthBB6)
alright so for all you people wondering about the prelude exhaust how the type sh is different than the base if you want a cat back for an SH and they only make them for the base you can buy a BASE cat back the "B pipe" will be a little bit longer than the one on an SH all you would have to do is make the cut to length and weld it back together to make it suitable for the SH.
If im not mistaken... which i looked at my manual of the two and compared
Old Sep 21, 2007 | 09:35 PM
roller3804's Avatar
As 98vtec stated inside diameter is what matters. What is best all depends on your goals. If you are gonna do just bolt ons and a tune 2.5 ID piping is perfect. If you are going for maximum power in an NA build 3" would be optimum.
Old Sep 21, 2007 | 11:24 PM
russlan44's Avatar
Default Re: (roller3804)
my 2.5 sounds deep before i hit 4k to 5k then its sounds ricey
Old Sep 22, 2007 | 08:00 AM
kadidle's Avatar
Default Re: (russlan44)
sounds weird but it seems like a 2.75 inch would be perfect between a 2.5 and 3 inch but no one really make 2.75 inch
Old Sep 22, 2007 | 10:02 AM
Si Speed's Avatar
Custom piping is cheaper. Just try to find someone who has a Mandrel Pipe bender to do it.
Old Sep 22, 2007 | 10:44 AM
Default Re: (si_speed)
Plus 1. Thats what Im doing. I bought a nice muffler and Im gonna get someone to install it amd supply all the piping for around 150 bucks.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si_speed &raquo;</TD></TR><TR><TD CLASS="quote">Custom piping is cheaper. Just try to find someone who has a Mandrel Pipe bender to do it.</TD></TR></TABLE>
TheKid1488
Jul 1, 2008 04:55 PM
AMLS4dr200whp
May 19, 2006 10:56 PM
acme
10
Dec 17, 2003 01:03 PM
AzntaggeR
May 26, 2003 09:47 PM
