rear disc brake conversion on 92 hatchback
i just need some clarification on the part number, this is what the sponsor told me whats included "26101 12436 Honda Civic EG6 Rear Disc Brake Conversion 3 w/ prop valve" is the text in bold the right part number?...
also i am waiting on a reply to see if it comes with ebrake cables... i am assuming i would need 92-95 Si hatch cables is this correct?
how are we supposed to know? there's no honda part number for a rear disc swap. All the parts from honda are sold seperately.
clarification on that mystery part number would help us understand
If you are doing a disc conversion go ahead and get the DC rear disc conversion. It comes with the ebrake cable, then visit fastbrakes.com and get ya some 11.1" NSX upgrades
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestSiR »</TD></TR><TR><TD CLASS="quote">how are we supposed to know? there's no honda part number for a rear disc swap. All the parts from honda are sold seperately.
clarification on that mystery part number would help us understand</TD></TR></TABLE>
oh alright no wonder i couldn't find it on HPD.com...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pythoner »</TD></TR><TR><TD CLASS="quote">that is JHOT's personal number...you have to have the SI ebrake cables</TD></TR></TABLE>
i think this person answered midwestsiR question... okay so Si cables, ill make sure that what i get sent.
yeah i got gsr brakes on my 94 hatch and every thing botled rite up.. no porblems at all.
good luck
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akunamatta »</TD></TR><TR><TD CLASS="quote">one more question, do i need to use the prop valve? or will my oem one work?</TD></TR></TABLE>
any rear disc set up will work:
90-93 integra
94-01 integra
92-95 civic
96-00 civic
and yes replacing the prop valve will make a difference. you will need a prop valve from a 90-93 integra or from a 94-95 integra ls (non-abs).
here is the part# 46210-sk7-q01, it will be stamped 4040 on it, this will verify you have the right one.
just be prepared to have stripped nuts and you might have to replace lines. swapping out the prop valve is the hardest thing to do in a rear disc swap. especially if things strip or break, just makes things harder.
90-93 integra
94-01 integra
92-95 civic
96-00 civic
okay wait wait everyone.... i am ordering EG6 rear disc brakes they should be exactly the same as the 92-95 si sold here in the USA.... i am not using integra rear disk, so do i still have to use the (4 wheel disc.) prop. valve that comes with the conversion?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akunamatta »</TD></TR><TR><TD CLASS="quote">okay wait wait everyone.... i am ordering EG6 rear disc brakes they should be exactly the same as the 92-95 si sold here in the USA.... i am not using integra rear disk, so do i still have to use the (4 wheel disc.) prop. valve that comes with the conversion?</TD></TR></TABLE>
if you are doing a conversion from drums to discs, which that's what it sounds like.
then they are all the same, except the itr of coarse.
and yes, you will need the prop valve. it all has to do with the amount of fluid that is sent to the rear. discs requires more than drums.
JHOT_Imports
138
Nov 30, 2008 06:49 AM
