Steering wheel shakes...
When i get on the highway and get up to speed...usually between 60-75mph depending on how the rush hour traffic is moving...the steering wheel vibrates pretty badly...the car itself feels fine...but the steering wheel...and the gas pedal a somewhat...shake...any ideas on what the cause of this could be and how i can fix it? It's a '96 Accord lx 2.2L non-VTEC..btw
Modified by StJimmy037 at 8:18 AM 9/18/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lunarone »</TD></TR><TR><TD CLASS="quote">try getting your wheels balanced</TD></TR></TABLE>
X3, mine did that before I got them balanced correctly. Are they aftermarket wheels? I'm not sure but if they are, you might need hubcentric rings.
Edit: Or you might have an alignment issue.
yeah...i went from stock steel rims to SSC Preformance Style 16x7...my new tires are a little wider too...the tires being Kumho Ecsta AST...the car was aligned when i got the new tires, also, i just had the front tie rods, struts, and i think ball joints all replaced and they aligned the wheels after that too supposedly...there's now a squeaking/creaking in the RF which i'm sure is just lack of lubrication in new parts...but i figured i'd throw that in there too just in case i'm wrong.
Forgot to mention...it tends to go away after 5-8 miles on the highway...but will occassionally start again for a bit and then again go away...quite annoying over the course of my, 80 mile round trip, commute to Lowell, MA everyday.
dohceg6whoohoo
May 7, 2006 02:40 PM
trooper0641
18
Dec 25, 2003 05:26 PM
